using V4 Hair morphs on Genesis 3
how do u access the hair morphs on v4 hair once it is autofited to Genesis 3? Can't seem to select the neck part of the hairs where the morphs are located.
some products don't translate with morphs once autofitted. However you should be able to transfer the morphs from the original V4 hair to the new genesis fit one via the transfer tool. Are you familiar with the transfer utility?
no i am afraid i am not. where can i get the utility? thanks in advance.
Not at home at the moment to work out the steps. but if I remember later I can write it up.
thanks so much
Here's a pretty good write up...
http://www.daz3d.com/forums/discussion/1866/ramworks-tutorials-pp2-and-hr2-to-figure-painting-genesis-in-zbrush/p1
thanks
