Geometry smoothing tool needs work.
EZ3DTV
Geometry smoothing tool in geometry sculptor needs more work. (please)
Most of the time it works worse than the smooothing tool in Hexagon.
And sometimes it makes DS crash ...
"Worse" how? "Better" how? There is nothing there to explain what you actually want.
Well, if you used it a lot (like some of us do) you would know what I mean.
All you have to do is use it to find out most of the time it does not work and there is no per use undo, so you are stuck with geometry being pulled way out of any reasonable context. With no per edit undo your only recourse is to bring the item in again and start over. The problems are so numerous it would be evident to even the most cursory users.
For me, sometimes it's a struggle to get things to smooth. The interface is a little clunky, is best I can describe it. Sometimes vertices won't smooth so that I have to click on another object then back on the object i'm working on to get things moving again. (This has also been a consistent problem with geometry editor since... I can't remember when.)
