getVertexGroup(index): unknown return type `const DzVertexGroup*'
I have two selection sets of vertices in the Geometry Editor. How can I obtain list of vertices in one of selection set? I tested this:
var oMesh = Scene.getPrimarySelection().getObject().getCurrentShape().getGeometry();
print(oMesh.getNumVertices()); // returns 4479 in my case
print(oMesh.getNumVertexGroups()); // returns 2, which is correct
print(oMesh.getVertexGroup(1).count()); // script crashes
but I get error message: TypeError: cannot call getVertexGroup(): unknown return type `const DzVertexGroup*' (register the type with qScriptRegisterMetaType())
Selected node is DzSkeleton.
The getVertexGroup is documented here.
  • Richard HaseltineRichard Haseltine Posts: 108,063
    A firsts tep would be to unpack those multi-operation lines into separate lines - it will be much easier to troubleshoot.
  • Apparently this is a known issue, you are advised to keep an eye on the change log and the documentation for DzFacetShape.
