Startup_Script
Hello
A going to do a moment naw a see this script (StartupScript) Beetwing my folder And i don't know why is comming Here ! How i can open it for see what is this ?
Thank you
  • felisfelis Posts: 6,509
    Have you tried open it with Notepad or Notepad++?
    Hello, Yes doesn't working ! I still don't know
  • crosswindcrosswind Posts: 10,271
    edited February 2025
    The script comes from Puppeteer plugin for saving initial status... as far as I can tell, . No need to touch it no matter you use Puppeteer or not.
    999 x 387 - 33K
    Post edited by crosswind on
  • crosswind a dit :
    Le script provient du plugin Puppeteer pour sauvegarder le statut initial... pour autant que je sache, pas besoin d'y toucher, que vous utilisiez Puppeteer ou non.
    Ok so should I leave it or should I not delete it ?
    chrisvn said:
    crosswind a dit :
    Leaving it there will be just fine ~
  • crosswind said:
    chrisvn said:
    crosswind a dit :
     OK thank you
