Daz Studio BETA - version 4.24.0.4!
123468
  • gramgram Posts: 68
    edited February 2025
    Dolce Saito said:
    Richard Haseltine said:
    Dolce Saito said:
    Is it reported somewhere or am I the only one with undo stack issues? The undo stack looses track on what is happening in the scene frequently. I don't know if these are repeatable or just happening randomly, but with a long timeline, I created a key somewhere, then mistakenly moved a camera on another frame, hit ctrl+z, then the key was deleted instead of latest camera movement. The put it in simple terms; there was no "camera movement" in the undo stack. Just an example. But all undo stack had was the created key. All limb movements, all camera movements, character poses are lost in the undo stack. Good that I saved the scene prior.
    Camera or view? By design the Perspective (and other) view is not tracked for undo - and is not remembered between sessions.
    Camera. I don't know why or when bug decides to trigger, but when it does, undo stack stops registering random inputs on characters/objects. It sometimes does it after creating a keyframe on character in junction with a recent camera movement (actual camera object).
    Oh yes, this happens to me relatively often. Just out of blue some actions/changes in the scene are not registered into the undo stack. Like posing a character on viewport - not in undo out of sudden. And then you do some other change and then it is in undo again.
    I have no idea what triggers it, only thing I can think of is that it usually happens if i've worked with daz for a longer time.
    Post edited by gram on
  • barbultbarbult Posts: 26,490
    I've had many more "fatal error and must close" crashes and "Not Responding" freezes with 4.23.1.27 than any previous recent beta. It usually happens after I have been working in the Viewport for a long time or using the timeline for dForce simulation. The longer I work, the slower it gets and the more likely it is to crash. I can't point to a repeatable scenario, but it is so frequent with this beta, that I felt I should mention it. I am on Windows 10, 32 GB RAM and RTX 3080 GPU.
  • tombraider4evertombraider4ever Posts: 751
    Edit, nevermind I found it smiley.
    Does someone know where the settings is to convert old ghostligt to work in the beta? I had saved converted ghostlights from the latest versions but they don't work.
    Post edited by tombraider4ever on
  • crosswindcrosswind Posts: 9,709
    I've not experienced crash yet with 4.23.1.27 on my side but I've been experiencing its performance turning lower and lower with long time's use, especially in Viewport.  With Win11, 128GB RAM, 4090, I still have to use Purge Memory script to improve the performance in Viewport from time to time.
    I think it's a long standing issue that DS has bad RAM management now thing's getting worse in PB.
  • ImagoImago Posts: 5,691
    Just tried working a bit longer with the latest beta to see if I get the same and I can confirm that, after a while I'm working on the scenes, DAZ Studio starts slowing down and freezing randomly.
    The freezing/slowing down happens more often if I move a prop or change a value, so it could be somewhat related to the Undo Stack that keeps registering Perspective View movements and ignores camers/prop/model's changes.
    But it stopped crashing on complex scenes load. It's something.
    There was recently an update to the G9 Dev Tools, but an error I reported almost two years ago has never been fixed. That help request was probably never reported to the developers, because customer service never responded to my ticket. Sure, they are behind, but TWO YEARS? When it gets to 3 years old, they just silently close it and mark it solved. What a crummy way to treat customers. But anyway, here is the error report I submitted:
    1142 x 787 - 118K
    Post edited by barbult on
    That file name has never been corrected in the script. Each time I had to modify it after updating G9 starter essentials ......
    Yup, me too.
  • barbult said:
    Yup, me too.
    Not, however, a Daz Studio issue - it is a content issue that needs to be handled by the content QA team.
    Although a search of http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log for Viewport does turn up a few hits, none of them has any relation to anything that would impact performance. With this kind of issue the first thing to do is check that it is not a third-party plug-in causing prob lems, by disabling them all and then seeing (to the extent that you can work) if the issue is resolved.
    barbult said:
    Yup, me too.
    Oh, OK. How can I get QA team's attention on this problem? Submitting a help request didn't work.
    barbult said:
    Yup, me too.
    Sorry, I don't have a better solution.
    I just did a spot render of an UltraScenery2 scene, and the spot render got "stuck" in the viewport. No amount of clicking in the viewport would clear the spot render. I even tried clicking with a few different tools selected. The cursor was an arrow, but there was a blue circle spinning around it. Daz Studio was still responding to other things, though. I could save my scene with V3D Super Save. I could click in the Scene pane and move items into an existing group. Finally I changed the draw style with the drop down menu and that cleared the spot render. I had successfully done spot renders in this scene several times before this problem occurred. I had no problem clicking in the viewport to clear those previous spot renders.
    1620 x 1065 - 567K
    It is beginning to sound as if theer may be issues with the GPU drivers.
    Via script it can, I think (cetainly most are, I haven't tried DoF though).
    See http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/elements/post_load_view_proxy_create/start (which I frequently, but not always, forget to mention)
    This actually seems to work, even DoF is there.
    I must say i am a bit confused with the purpose of these proxy nodes - what is the general use case behind them?
    They allow the creation of remote-control nodes, items in the scene that can be used to control properties on other item(s) (ERC links work only within an item if they are to be saved) and they can also do thinks like making material properties (not animatable in themselves) aniamtable by linking them to regular, aniamtable node properties.
    After some time the proxy camera works quite well, i noticed one small bug. When i create the proxy it has all the camera properties (Focal length, Dof, Focal distance) - but when I reload the scene the proxy node no longer has these extra parameters. I have to re-create it.
    Of course this is very simple, but thought to note. Maybe there is similar issue with other types than just cameras.
    The other potential use cases are also relatively interesting, have to try them out some day.
    I haven't updated NVIDIA graphics drivers. I'm using 560.94, which I've had for several Daz Studio beta builds now (over many months). As I understand it, Iray hasn't been updated, so I think this graphics driver should still be working OK. Right???
    332 x 139 - 11K
    It does seem odd, but it may be worth  a clean reinstall - things like this are GPU-related, and it is possible that something else might damage the driver. Of course it is also possible that the GPU might have developed hardware issues, which would be even worse.
    Visible in Render does not work on bones when the figure is in Base Resolution. I am rendering in Iray. This is not a new issue, but persists in 4.23.1.36 Public Build. Several of us discussed this in this thread. Based on that discussion, I submitted a ticket on October 4, 2024 (Request #463526 Visible in Render does not work on a figure's bones if the figure is in Base Resolution.). That ticket has not received any human response, so as a last resort, I'm reporting it here, in hopes that someone will see it, fix it, or explain why it is supposed to be that way.
  • VisuimagVisuimag Posts: 578
    Not sure if anyone has mentioned it, but applying poses is MUCH faster in the latest beta! Like Genesis 1, mid 20-teens fast!
    The crashes when loading a complex animated scene returned in the very latest beta. So happy. indecision
    Please provide samples, and make sure they are not involving some common element (such as active Mesh Grabber modifiers).
    Like this?
    As I said before, this doesn't happen in 4.21, only in 4.22 and 4.23. The error orginates from QTCore.dll, TBB.dll, DazCore.dll and some core Windows system DLLs.
    It can't be just my fault, since the crash happens only in the latest releases.
    548 x 546 - 171K
    Post edited by Imago on
  • A crash dump may help, but sample scenes that trigger it will also be useful.
    It is very nice to have the familiar menu order restored in the latest beta. I didn't know the change was an error, and I was having trouble adapting to the new location of often used entries.
  • > Reverted update to NVIDIA Iray 2024.0.4 (377400.3959a)
    Richard, can we get any information on why Iray update was reverted?
    I am assuming there were compatibility issues, but what does that mean? Will the developers stop updating Iray because of that or the update was just delayed and for how long?
    I am asking this because some people may upgrade to RTX 5090 and might be wondering whether Daz is still committed to updating Iray for full / proper support of said cards.
  • FrankTheTankFrankTheTank Posts: 1,535
    edited March 2025
    I've noticed something weird going on when comparing renders in 4.23 beta vs 4.16.0.3. This is the same exact scene rendered in both. Beta is on the left side.
    You can see the corner trim of the house behind the bush on the left pretty much "dissapears" in the beta render.
    I've only started testing, as Ive been thinking about upgrading. But this has me concerned. No idea what caused this, I'll try to see if i can find more examples.
    My driver version is 546.01. RTX 2060
    As a side note: if I do want to upgrade from 4.16.. what is the lowest version of DS that will allow me to use all the latest features of VDB related stuff. Will 4.21 do that, or do I need 4.22? I just want the most stable version of DS that will run VDB Essentials. I know 4.22+ is needed for OmniHair, but if I only care about VDB effects is 4.21.0.5 good enough for that?
    1920 x 1080 - 4M
    Post edited by FrankTheTank on
    This keeps happening and very often: If there's a single empty or "orphaned" restraint in the scene (the involved props have been deleted) it multiplies so many times at every saving of the scene that reaches a so big amount that makes the reload of such scene so long that takes minutes for an empty one...
    To get rid of such amount I have to use an autoclicker set to send a click on the "delete" button once every 50 milliseconds... and it takes about nine real minutes to complete the task... Just make the math to find how many replicated empty restrains it creates.
    As I can see, it doubles the restraint at every save: From one to two, then four, eight, sixteen... It replicates the empty restraints esponentially.
    Already sent a report long ago, still got no answer.
    207 x 1074 - 131K
  • Richard HaseltineRichard Haseltine Posts: 109,242
    There were bugs, I wasn't told what and haven't checked to see if nVidia gives details. I am surprised they would switch compilers in the middle of a major version (2024.0 to 2024.1) so it would seem possible this was required to address the issues with 2024.0, but that doesn't mean that is the case.
    Can you get us any official statement on future Iray updates please?
    edited March 2025
    In Smart Content, Browse to Folder Location... never works for me on any product. Browse to File Location... works fine on individual assets within the products.
    548 x 392 - 52K
