Mesh Grabber 'Undo'
Does the Mesh Grabber tool have an edit/undo feature?  When I use it, and attempt to undo a mistake, using edit, it doesn't work.
  • crosswindcrosswind Posts: 9,649
    edited February 2025
    If there's another (or more) object in the scene that has the same Node Name as the one which you're manipulating with Mesh Grabber, Undo won't work.
    It's one of the issues of Mesh Grabber. To resolve it, the easiest way is to change Node Name of this object to a unique one before using Mesh Grabber... via Edit > Figure > Scene Identification...
    Post edited by crosswind on
  • dash2128dash2128 Posts: 736
    Oh?  Okay!  Thank you!
    Think I figured some of out.  Thanks again!
    Post edited by dash2128 on
