InaneGlory's Photo Studio - Point and Shoot Iray - White Ring
This may be a silly question but when using InaneGlory's Iray Light set Specifically (InaneGlory's Photo Studio - Point and Shoot Iray) there's a white ring that surrounds the scene.  It's visible in all my renders and I can't for the life of me figure out how to turn it off.  I render my backgrounds separately and having this thing in there is a real pain.  Anyone know how to turn off visibility on it?  Unfortunately I can't select it in the render so I'm not even sure what element it's part of.  Any help on this would be appreciated.  I also render my backgrounds seperately so covering it up just won't be an option.
Thanks
Kris
  • thd777thd777 Posts: 945
    That's not a just white ring. It is one of the lights in the light set. It is connected to "Arm 4" in the light rig. If you remove it, you'll change the lighting. It will look different than what is intended by the setup (In this  case the ringlight softens the overall shadows). If you don't want it in your image because you are rendering the background separate, I would recommend to use a different light setup (the same set has several that do not utilize the ring light).
    Ciao
    TD
  • Thanks THD.  I suspected the setting I was using must have assumed you were using a backdrop.  I've since chosen other lighting options.  Your assistance is greatly appreciated.
