[Solved] Issue with surfaces in Daz 4.22
dogcatdogcat Posts: 52
edited January 2025 in Daz Studio Discussion
Hi,
For some reason, I can't find properties per surface in the surfaces tab. And some are missing, like the base color. Even when I drill down to the base tab, I can't see it.
I can only see them when I select All, and this is not good because it selects all the surfaces, and I only want one.
I attached images so you can understand what I mean.
Thanks,
DC
Post edited by dogcat on
  • dogcatdogcat Posts: 52
    Problem solved.
    It was a UI issue related to the layout.
    I deleted the layout.dsx file in C:\Users\<username>\AppData\Roaming\DAZ 3D\Studio4 and it fixed the issue.
  • It wasn't a layout issue, the "Show Sub Items" box wasn't checked.
  • crosswindcrosswind Posts: 10,267
    It could be... as Show Sub Items option is saved as "ShowRecursiveGroups" within Layout *.DSX file. If having deleted a Layout in which this option was saved as "no", the default Layout with the option set as "yes" can fix the issue ~~
    True, but it was a single setting that was "wrong" not an bad layout in general.
    Oh, how did I miss that?
    Thanks for responding and clarifying.
