Characters look a bit distorted....
Halcon Bluesky
Hello, I am still working on my project.
Do you have this kind of Environment? https://www.daz3d.com/simple-serenity-house
My problem is after populating the elements for the environment, including people, Camera 5 is activated by default.
I have not switched to any other view.
However, I see some distortion in the scene, is there a way to maintain focus without sacrificing the scene?
Thanks in advance for your help.
Post edited by Halcon Bluesky on
If you with distortion is referring to a slight curving of the scene, then it is due to the focal lenght.
To avoid that you need to increase it to at least 50 mm. But in order to keep the approxiamte same view, you must move the camera backwards, and if you hit a wall you will have an issue. You might be able to hide the wall.
I wonder why this vendor always uses a Scene rather than Scene Subset in the product ~~ !?
They set Focal Length as 40mm on Camera 5 so as to have a wider angle while leave some "distortion" there... You can just reset it to 65mm, zoom out a bit and fine tune the composition. You won't lose the focus evne with DoF turned on.
