Show Us Your Bryce Renders Part 13
17475777980100
  • HoroHoro Posts: 11,455
    edited January 2025
    The terrain consists of 9 tiles from Tileable High Resolution Terrains with a material from the same set (the clouds as well) and High Resolution Terrains 2. In the distance the ground plane with a material from Vegetation. The aeroplane is the Biplane. Ambient light by the WhiteSpherB7 HDRI and the key light by the sun.
    Gnarled Land
    1200 x 800 - 266K
    Post edited by Horo on
  • mermaid010mermaid010 Posts: 6,116
    Awesome scene Horo, very realistic scene, thanks for the comment.
    Thank you mermaid.
  • Bunyip02Bunyip02 Posts: 9,288
    Horo - Islands look fantastic ! Love the Biplane render !
    Electro-Elvis - Landscape looks wonderful !
    mermaid - Robot render is captivating !
    edited January 2025
    810 x 607 - 306K
    Post edited by Bunyip02 on
    edited January 2025
    Bunyip02 - thank you - and thank you also for the Freebie.
    The NURBS cubes come with Bryce 7.1, within a slightly smaller copy, all with a material from Stylised Rendering. The figure on the cubes are Warlocks, around 20 years ago exported from the Game Studio 5, they have the same material like the cubes. Background and specular by an unpublished HDRI and by the sun some light and specular. The difficult to perceive icy figures will be melted away in spring.
    Icy Monument
    1200 x 800 - 327K
    edited January 2025
    Thanks Bunyip02 for the freebie and comment.
    Awesome render Horo. The Stylised Rendering is a very interesting set, I watched the ice videos about an hour ago.
    Post edited by mermaid010 on
    mermaid - thank you. Your comment above to look into this set inspired me to do the same. It's a while since we made it and a refresher was quite interesting, we tend to forget things.
    Horo - Superb Ice Warlocks - will be in the mid 30s to high 30s degrees celcius here over the next little while, a breath of winter would be very nice at the moment !
    bunyip02 - thank you. Winter here, I look forward for warmer weather, I envy you wink
  • HansmarHansmar Posts: 3,166
    Nice presentation of that alien device, Mermaid010.
    Beautiful tiled terrains, Horo. Wonderful winter / ice sculptures scene.
    Thanks for another great freebe, Bunyip02.
    edited January 2025
    Thanks Horo, you mentioned this product in a render not so long along and after viewing the product page, I added it to my wish list. It is a very unique and interesting concept of rendering.
    Thanks Hansmar
    Another Hdri backdrop render; using the well by Bunyip02. Thanks Bunyip02 for the model. The Hdri is a freebie - anvil_by_macsix-d6vv4hs , I like the fluffy clouds.
    1000 x 750 - 403K
    Hansmar - thank you
    mermaid - thank you. Very nicely presented Well by Bunyip02.
    Thanks Horo
    mermaid - Lovely scene, glad you are finding uses for my models !
    edited January 2025
    Mermaid010. lovely render with the well. Fantastic HDRI sky.
    I used some things from DAZ again to make a render. I used an environment called 'the backfence' and changed a few textures (ground, poles, cloth). I tried changing the textures of the boxes too, but these were simple cubes and I could not get nice enough view with procedural textures on the. The boy is a Genesis figure with fitting clothing. The pot is from Horo and the sky from Karanta. The terrain is from one of thesets I have, but did not note down which one. The terrain texture is from David B, I think.
    1370 x 651 - 719K
    Post edited by Hansmar on
    Hansmar - very nicely done scene.
    Thanks Bunyip02 for the comment and the beautiful models you are sharing with us.
    Hansmar - thanks, lovely scene, well done.
    edited January 2025
    Horo, Mermaid010, thank you.
    I have another one. I used the Atlantida copter, a Genesis male and Genesis 2 female with clothing for them. To allow this scene to be saved in Bryce, I deleted some parts from the copter that are not visible in the scene, as well as invisible body parts of the people, including those underneath clothing. I changed the texture of the front window to make it more transparent. The sky is from the Landscape under fantastic skies. I added a fill light in the copter, because it was otherwise too dark for my liking.
    1370 x 651 - 769K
    Wow Hansmar lovely setup, the lighting is nice
    edited January 2025
    Hansmar - beautifully done and lit scene.
    The objects were made in Wings3D and with the method of the videos 1-5 from Stylised Rendering rendered: without light with strong Haze, exported and imported as terrain. This terrain lit by a Parallel Light through a isometric lens rendered and exported. This new terrain replacing the previous one given a new material, within two coloured mirrors and with negative Parallel Light coloured and rendered. Below the render sequence.
    Outlined Objects
    Render Sequence
    1200 x 750 - 131K
    800 x 100 - 22K
    Beautiful results Horo, I'm haven't play much with this set due to bad arthritis days.
    Hansmar - Wonderful renders, copter is my favourite !
    Horo - Awesome widgets ! I take it you meant Wings 3D instead of 2D ? Downloaded and installed it, had a play with it, very nice modeller !
    mermaid, thank you. It took me a few days to get it right.
    Bunyip02 - thank you, yes Wings3D, I corrected my mistake.
    Mermaid010, Horo, Bunyip02, Thanks.
    Horo, lovely presented items.
    Thank you Hansmar.
    edited January 2025
    Two by 90° rotated reflecting tori and in each one on a wall a thinner torus with a bit of colour and specularity, no light. Specular by an HDRI from Hyper Textures Base, no sun.
    Torus Loops
    1000 x 1000 - 450K
    Wow a beautiful colorful Abstract Horo, well done.
    Fantastic abstract, Horo.
    Thank you mermaid and Hansmar.
