Baking an environment to a HDRI Cube
I am working on my architectual project with a quite render intense outside view from the apartment's inside.
In order to save render time, I would like to bake the view on the outside yard onto a cube, that has the outside baked into a HDRI image.
Any ideas, how to achieve this?
  • FishtalesFishtales Posts: 6,212
    Use the spherical Lens Distortion setting under lens in the camera panel.
  • SofaCitizenSofaCitizen Posts: 2,061
    edited January 17
    It's been a little while since I watched it but I think WPGuru's YouTube video "Creating and Working With Your Own HDRIs" covers it if you need more detail:
    I think the forum drops the timestamp from the URL but jump to about 1hr 4mins in for the actual creating a HDRI part.
    Post edited by SofaCitizen on
  • MasterstrokeMasterstroke Posts: 2,305
    Thanks, I actually thought about this, but my doubt has been, that I intended to map it on a cube.
    Wouldn't a sperical lens distortion projection lerad to nasty distortions when mapped on a cube?
    ( a cube, for keeping polygoncount low and the inner yard to be mapped is shaped rectangular anyway.)
  • chris-2599934chris-2599934 Posts: 1,904
    An HDRI doesn't have any polygons, it's an image that wraps around your scene like a sphere
    Sorry for confusion. I am not talking about the environment tab.
    I can use a HDRI image as a texture map, like any other image format. By this I can use a cube and map an HDRI image on it.
    I'd like to create and use a custom polygon cube, instead of a cubic lighting from the environment tab, because it is easier to control in size and position and I can create custom material zones on it.
    This cube needs to be mapped with a 360° HDRI image.
    You can turn the Environment into a box with a spherical hdri and shrink it to fit inside a room so a spherical hdri should fit around a cube. Haven't tried it but I have used the environment in the environment box to fit in a room to get the lighting.
