Daz Studio BETA - version 4.24.0.3!
124678
  • barbultbarbult Posts: 26,165
    I wonder if the failure to apply Render Settings Presets has to do with switching render engines back and forth between Filament and Iray.
  • crosswindcrosswind Posts: 9,538
    Most likely you are correct. I did some filament rendering as well. Then I just had some tests by switching back 'n forth, Environment is back. But I still think it's a bug.
    I haven't figured out a repeatable scenario to recreate the problem, either, but it has happened to me twice in the last couple days.
  • ImagoImago Posts: 5,652
    crosswind said:
    The property positioning issue in Surfaces pane has been fixed in the latest DS PB - 4.23.1.20. Thank you very much, Dev. TEAM !! yesyesyeslaugh
    I feel all the animation tools are left terribly behind... I don't see a single fix on those tools or any related function.
    It's easy to reproduce the issue on my side.
    1) Clear the scene. Now Engine in Render Settings pane is Nvidia Iray.  Load a Render Settings Preset. No Environment path appears in Render Settings pane.
    2) Switch Engine to Viewport then switch it back to Nvidia Iray, Environement path appears ~~
    I'm afraid you're right ~~ my friend. I'm sorry that usually we have no other option but just wait ~~
  • Richard HaseltineRichard Haseltine Posts: 107,893
    Enabling the Iray DrawStyle adds an enviornment settings node, the empty scene won't have one until that or a render are done. No settings node should tie the proeprties to their default values so I am surprised it wasn't an issue before.
    barbult said:
    How can I track down the source of these [WARNING] messages in the log when I start DS 4.23.1.20?
    2025-01-17 00:15:32.174 [INFO] :: Loading Actions: C:/Users/Barb/AppData/Roaming/DAZ 3D/Studio4 Public Build/actions.dsx
    2025-01-17 00:15:32.218 [INFO] :: Loading Custom Actions: C:/Users/Barb/AppData/Roaming/DAZ 3D/Studio4 Public Build/customactions.dsx
    2025-01-17 00:15:32.237 [WARNING] :: \src\sdksource\interface\actions\dzactionmgr.cpp(2742): No file or script specified for custom action '97a02b64-c41a-4add-b3f0-672a552f4776' in interface file.
    2025-01-17 00:15:32.237 [WARNING] :: \src\sdksource\interface\actions\dzactionmgr.cpp(2742): No file or script specified for custom action 'ea99a9d8-3a25-4e92-8f0e-bc1d36567bbe' in interface file.
    2025-01-17 00:15:32.238 [WARNING] :: \src\sdksource\interface\actions\dzactionmgr.cpp(2742): No file or script specified for custom action 'f95a7549-0906-4bea-
    b23d-05ce9c40c6fb' in interface file.
    2025-01-17 00:15:32.239 [INFO] :: Loading Menus: C:/Users/Barb/AppData/Roaming/DAZ 3D/Studio4 Public Build/menus.dsx
    2025-01-17 00:15:32.269 [INFO] :: Loading ToolBars: C:/Users/Barb/AppData/Roaming/DAZ 3D/Studio4 Public Build/toolbars.dsx
    Edit: Oh, maybe I can figure it out by looking in the C:/Users/Barb/AppData/Roaming/DAZ 3D/Studio4 Public Build/customactions.dsx file.
    Edit 2: No, I couldn't find any info about what they should have been, so I just deleted those entries and resaved the file (while DS was closed).
    Custom actions are about the only bit of DS that uses absolute paths even if the files are in a content directory, check the Custom entries in Window>Workspace>Customise to see if there are any orphans.
    Nope... applying a Render Settings Preset has nothing to do with enabling Iray Drawstyle. In DS 4.22, after applying a Render Settings Preset, Tone Mapper and Environment Options nodes are placed into Scene pane, and Environment path appears in Render Settings pane.
    In DS 4.23, Environment path doesn't appear in Render Settings pane... even if switching to Iray Drawstyle. The only way to show Environment path by now is to swith options in Engine dropdown list.
    @crosswind What do you mean when you say "Environment path"? Do you mean the Environment Options node in the Scene pane, or the Environment section in Render Settings, or the Environment Map part of the Environment section of Render Settings? I have a startup Scene that contains Environment Options, Tonemapper Options, and Filament Draw Options. That Scene loads with the Environment and Tone Mapping sections in Render Settings, and the NVIDIA Iray (MDL) render engine. The default ruins HDRI is in the Environment Map. I think all that might be why I'm not fully understanding your scenario.
    How do I check for orphans?
    edited January 17
    What I meant is the Environment section in Render Settings pane. It's officially named as Path (or Group...), isn't it ? (in ss1)  Again, in DS 4.22, after loading a Render Settings preset, I get the result in ss2. In DS 4.23, I get the result in ss3 ~~
    1299 x 1373 - 273K
    2560 x 1392 - 366K
    2560 x 1392 - 282K
    Post edited by crosswind on
    Open Customactions.dsx by Notepad++, search by the GUID, you can find the path of script, then check if the script file physically locates there?
    I understand now. Thanks for the illustrations!
    When I looked in that file yesterday, the file path for the suspect GUIDs was "", so it gave me no clue. I didn't know how to find out what those GUIDs were supposed to represent, so I just deleted those entries. I don't know how I got custom actions with null file paths. I wonder if it had anything to do with Update and Merge Menus?
    @crosswind I removed my startup scene file from DS 4.23.1.20 for testing.
    1. If I switch to NVIDIA Iray drawstyle, the Tonemapper Options node and Environment Options node appear in the Scene pane and the Tone Mapping path and Environment path appear in the Render Settings Editor tab, if the render engine is NVIDIA Iray (MDL).
    2. If I switch to NVIDIA Iray drawstyle, the Tonemapper Options node and Environment Options node appear in the Scene pane but the Tone Mapping path and Environment path do not appear in the Render Settings Editor tab, if the render engine is Viewport).. (I didn't check other engine types). The Tone Mapper Options node and Environment Options node settings can be accessed in the parameters pane. But changing those only seems to affect the Iray preview in the viewport. In an actual render, these options settings seem to be ignored in this configuration. Even though the render engine is Viewport, the render is not the Iray preview shown in the Viewport! It appears to be something else, maybe Texture Shaded.
    What does this have to do with the inability to get applied presets to work? I am still unable to reproduce that on command, but it does still happen to me at times. I also get into situations where the HDRI applied by an Iray render preset does not change the HDRI in the Filament viewport. Sometimes it changes; other times it does not. I have wasted hours and hours trying to understand what causes these issues, and I cannot come to a conclusion. I still don't have enough data to submit a useful help request at this point.
    Probably... I never did Update and Merge Menus before so not sure if it would remove somthing in Customactions.dsx. Usually if I lost something in F3 with invalid GUID / action path of whatever, I just removed the items then save the layout.
    Same on my side (since 4.15 or 4.16... ?) but this behavior shouldn't have had anytying to do with Loading a Renderings Preset. Why did one have to switch to NVIDIA Iray drawstyle in 4.23 before loading a Renderings Preset ?  It works all well in DS 4.22.
    However, the most interesting thing is that I cannot reproduce the issue now !! I really don't know why, haha ~ !
    1. If I switch to NVIDIA Iray drawstyle, the Tonemapper Options node and Environment Options node appear in the Scene pane but the Tone Mapping path and Environment path do not appear in the Render Settings Editor tab, if the render engine is Viewport).. (I didn't check other engine types). The Tone Mapper Options node and Environment Options node settings can be accessed in the parameters pane. But changing those only seems to affect the Iray preview in the viewport. In an actual render, these options settings seem to be ignored in this configuration. Even though the render engine is Viewport, the render is not the Iray preview shown in the Viewport! It appears to be something else, maybe Texture Shaded.
    Also same on my side... With 3DL engine, the same thing will happen... because those paths / groups are hidden in Viewport / 3DL engine. The moment you switch back to NVIDIA Iray, you'll see them there.
    I'll do more tests then...
  • MKeyesMKeyes Posts: 474
    Soooo - is this new? I can't get it to open, just this message.
    1038 x 733 - 923K
    You run it with Admin ?
    Things got even worse with those crashes when loading a saved scene while having a scene already loaded. Now it happens even with small scenes and NO stuff altered with Mesh Grabber.
    It is enough for the scenes to contain the simpliest animations, it crashes on load. Until now the scene needed to be bigger than about 50 megs, now it crashes even with the small scenes.
    This issue makes impossible start any batch render system and even work properly on my scenes.
    So, without any animated range, everything works fine ? With animated range, doomed with crash ?
    Animated range can't be removed, it will be always at least 30 frames. I mean anything moving in the scene, especially rigged chars.
    The crashes are quite random but they happen only in any release after 4.21.
    In 4.12 and 4.21, where I'm forced to work due to these bugs, the crash don't happen, in any case. Even the most complex and heavy scenes load and work correctly in these releases.
    Has ANYONE else reported the same problem, or is this unique to you?
    I reported here and in the helpdesk, I don't know if anyone else have the same problem.
    I suspect it is because of that annoying popup window I get every time I want to create a new scene or load something. The crash doesn't happens where that popup wasn't integrated yet, so my guess could be exact.
    What pop-up?
    What pop-up?
    That invasive window with store ads that appears when you try to create a new scene. Since it's absent in 4.21 and appeared in 4.22, where the issues started, I guess it's because that popup gets in the middle of the loading system.
    What pop-up?
    It doesn't appear when loading, however, as you asserted - and it doesn't leave relics in the scene so no, it isn't going to be your issue.
    I didn't do anything different from any other time or the previous versions. This is new. Windows based OS always or automatically run thing with Admin? I've never seen this message before so I have no idea why it popped up with this new release.
  • Dolce SaitoDolce Saito Posts: 196
    edited January 30
    Is it reported somewhere or am I the only one with undo stack issues? The undo stack looses track on what is happening in the scene frequently. I don't know if these are repeatable or just happening randomly, but with a long timeline, I created a key somewhere, then mistakenly moved a camera on another frame, hit ctrl+z, then the key was deleted instead of latest camera movement. The put it in simple terms; there was no "camera movement" in the undo stack. Just an example. But all undo stack had was the created key. All limb movements, all camera movements, character poses are lost in the undo stack. Good that I saved the scene prior.
    Post edited by Dolce Saito on
