NVidia 5090
2456713
  • kyoto kidkyoto kid Posts: 42,117
    ..the VRAM dedicated to emulate RTX on older cards is about 1GB
  • JamesJames Posts: 1,179
    edited January 2025
    It seems GPU tech has reach its limits.
    That's why they turn into AI for lower power consumption.
    They could increase raw performance, but that would just increase the wattage a lot more
    Maybe the tech has reach almost its limit.
    I would bet 6090 would be more AI powered, instead of raw performance
    Post edited by James on
    I am not sure what you mean here - performance is improved, but they are headlining the improvements in its execution of AI related tasks since that is what is currently in.
    edited January 2025
    Performance continues to improve and always has room for further enhancement. However, as GPU technology approaches its efficiency limits, achieving double or triple the raw performance will increasingly require a proportional increase in power consumption.
    Since frames per second (FPS) is often the standard metric for GPU performance, it may become more efficient to rely on AI to maintain high FPS rather than depending solely on raw hardware capabilities. AI could enable GPUs to deliver similar performance at a significantly lower power cost with the Fake Generated Frames.
    This situation parallels the evolution of binary supercomputers. In the past, supercomputers required enormous amounts of space and power. Over time, advancements in technology made them smaller and more energy-efficient. But as binary computing approaches its efficiency ceiling, doubling the capability of current supercomputers might require twice the space and power unless a breakthrough, such as quantum computing, emerges.
    (Chat GPT help me to compose better wording, hahaha...)
    So that's why I think in 6090 and above, we'll probably see more of AI enhancement, rather than raw performance, due to power consumption consideration.
  • DiasporaDiaspora Posts: 523
    It doesn't include an Iray benchmark, not sure that's currently possible, but this video seems like it would have some relevant benchmarks for us.
    So, if we can expect a comparable iray performance boost as with what we see from his blender and maya arnold results, it would be around 40%. Maybe iray will be better because it's an Nvidia developed render engine.
    My feeling is that AI enhancements isn't so much for power consumption, it 's more to what currently brings them money. And that is AI acceleration. Graphics became sidebussiness. They improve AI performance, their R&D goes that way since that's where their market currently is. "Raw performance" improvement seems to be more due to small tweaks.
    That's why there 's little improvement in performance when compared to 4000 series when they turn DLSS off. And that 's why they "improved" DLSS frame generation to generate not one but three "fake" frames. It 's simply due to AI part being better when compared to last generation so it can do that in same amount of time.
    As for power consumption, I just watched Hardware Unboxed video about MSI RTX 5090, it uses 750W. That 's not realy considerate to power consumption. Sure, you get more frames than 4090, but they 're product of DLSS Multi Frame Generation, so it seems that only real improvement is in that part of GPU.
  • NylonGirlNylonGirl Posts: 2,290
    I think for the GPUs and CPUs the biggest factor in performance improvement has been decreasing the size of the inner workings. The smaller nanometer components are able to do the same amount of work with less power, so they can do even more work with the same amount of power. If they hit a plateau, it will probably be because they can't go from 2nm to 1nm or something like that. Then they will have to either increase power consumption or let the marketing team hype up how the LED lighting effects improve performance.
  • ArtAngelArtAngel Posts: 2,059
    It is impossible to benchmark a GPU in all fairness if we enable AI. AI does not represent the frame rate of a GPU. AI are fake frames. Similar to Photoshop when we color in a background versus let AI fill it with calculated pixels. AI is simply calculating pixels to render and what we get may not be as consistent or stable as what one would get from GPU. The 4090 has fake frames but not near as many, so essentially the 4090 would benchmark better against a 5090.
  • nonesuch00nonesuch00 Posts: 18,822
    Need much, much faster raw ray tracing render engine.
  • I just got a 4060ti with 16gb of vram for a really good price and that is my first 40 series card. I wont touch a 50 series till the prices come down and we find out if they are gonna burn up LOL. I would look into getting a good deal on a 40 series card now that everyone is gonna go 50 series.
  • Noah LGPNoah LGP Posts: 2,617
    I'm interested by inZOI so ACE AI making smarter NPC is welcome.
    That's what I have and for Daz I'm quite content with it. Both my monitors are 1080p and max out at 60fps, so in gaming I never seem to max it out, I can run ultra on most of what I have with no issues. Going above and beyond that seems overkill for me, but I know some people have far higher resolution monitors from mine, so the demands might be different for them. For a still-rendering program like Daz, a 5090 would be like buying a Ford Super Duty F-450 even though you don't have anything big to haul. Complete with horrible gas mileage. Or in this case starving for electricity.
    And that rusty rail yard would still probably stutter in the viewport, haha.
    On my PNY GeForce RTX 4070 12GB, I did some FHD renders of a Genesis 9 character in a T-Pose using one of Colm Jackson's iRay rendering light setup products and it does help speed up render times and gets competant lighting quickly,  relative to my attempts, I still feel render times for FHD should be 30 seconds or less. That seems a few generates of cards off still yet.
  • suffo85suffo85 Posts: 212
    edited February 2025
    At the time I post this (1pm 2/2/25), there's three MSI systems on Newegg that can be backordered with 5090s due to ship at the end of the month.  Figured I'd pass this info along since these cards are basically sold out everywhere.
    Links..
    https://www.newegg.com/p/N82E16883151592
    https://www.newegg.com/p/N82E16883151593
    https://www.newegg.com/p/N82E16883151594
    Post edited by suffo85 on
  • I would not be in a hurry to order a 50 series GPU just yet, since it has already been confirmed on another thread that the current version of Daz does not work with the 50xx series cards (you will get a "no CUDA device found" error if you attempt a render).  Best to wait until Daz is updated (and make sure the updated version doesn't have other issues that will interfere with your work) and let NVidia build up inventory to meet demand over the next few months...
    Daz Studio works with the 50x0 series as far as I know, Iray requires an update (from nVidia, which will then need testing before release in DS).
  • KenYanoKenYano Posts: 138
    ANd here I thought this would be the gen I upgrade. Skip every other gen and get a 5080 one day but it looks like I should keep using my 3080Ti 16gb Laptop. I hope 3000 series cards don't start wanning this year for Daz performance.
  • gramgram Posts: 68
    For me the biggest benefit would be the increased VRAM, coming from 4090. I have doubts render speeds would increase  drastically compared to vram benefits.
    I think also 5090 is better value than 4090 from VRAM pov - price per gb is less.
    Post edited by gram on
  • jbdiminniejbdiminnie Posts: 105
    Richard,
    This was posted on February 1 in a thread asking if 5090 was supported by Daz, which indicates that 4.23 doesn't support 5090s at the moment, unless you know something different...
    pocketnew said:
    Unfortunately, RTX 5090 are not supported at this point, nothing renders (I'm using latest drivers).
    2025-02-01 17:19:41.743 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: Cannot render: found no usable devices. Please update your NVIDIA driver (www.nvidia.com) to at least 537.13, or enable CPU rendering.
    2025-02-01 17:19:41.743 [ERROR] Iray :: Invalid parameters (NULL pointer).
    Post edited by jbdiminnie on
    Richard,
    Which, as I wrote, is Iray, not Daz Studio itself - other GPU-enabled features (dForce, say, or Filament) do, as far as I know, work with 50x0 cards.
    Fair enough, but since rendering scenes is (I assume) a big part of what folks do with Daz, I just wanted to point out that the 5090 does not yet work for that aspect of the program (until the Iray part of the software gets updated).  Hopefully the NVidia update to Iray will have some goodies to help out legacy cards (like the 30xx and 40xx series) as well, since I notice that the latest driver adds new features to those cards that weren't previously available, such as frame generation.
  • MIH_BADMIH_BAD Posts: 69
    EDIT: I just opened an IT ticket heart with DAZ and another one with NVDA, I will update here
    I updated to the latest drivers:
    I just got the RTX 5090 and it's not rendering ... the simulation is so fast ... but the render is just a BLACK SCREEN crying
    Any idea how to get help?
    PS: There was no auto update / check for update said latest version already installed
    From the LOG:
    Post edited by MIH_BAD on
    From the LOG:
    The 50x0 cards are not supported by the current version of iray. According to information I was given yesterday the 2024.0 version of iray (which may have had support) had bugs and will not be integrated, the new 2024.1 uses a different C++ version and so cannot be integrated into DS 4.x.x.x. 50x0 support will therefore have to wait for the next major version of Daz Studio, for which I do not have an ETA.
  • algovincianalgovincian Posts: 2,670
    From the LOG:
    Thank you for this very useful piece of info - it's much appreciated.
    - Greg
  • bluejauntebluejaunte Posts: 2,009
    From the LOG:
    Daz needs to communicate very clearly/officially and very soon IMO that a 5090 is not going to work until Daz Studio 5.
    From the LOG:
    Oh my GOD !!! 4.000 USD and now I have to wait 1 - 12 months for the newer version crying  anyone wants a 5090 cheeky
    From the LOG:
    Good news is you can probably sell it without too many issues ;)
  • If Nvidia start using this new version of C++ to write the newest drivers for their older generation cards then we might all be stuck until Studio version 5. As I understand it Studio version 4 plugins propabaly won't work on version 5, so it's a big uphill climb looming ahead.
