Error
people, can I still snort this scene or is it completely gone?
  • CES3DCES3D Posts: 245
    What file were you trying to open? Was it a scene file?
    First, how about checking the log file as instructed in the error message?
    1105 x 558 - 266K
  • yes it is a scene. I'll take a look when I get home now I'm traveling to work. I just wonder if there is a way to reverse it. I'll check the error and get back to you right away.
  • this one ??
    1348 x 571 - 75K
  • %appdata%/daz 3d/studio4/log.txt
    Paste that into the file browser's address bar and the log should open in the default application for .txt files (Notepad if you haven't picked anything else).
  • I'm sorry, it's too complicated, you wrote it to my dull head. I don't understand I'm sorry
  • it opened me for sure what I sent it on the picture is a logfile
  • frank0314frank0314 Posts: 15,103
    Browse to this location C:\Users\(YOUR NAME)\AppData\Roaming\DAZ 3D\Studio4 and look for the log.txt
  • i already did what now ?
  • it shows me this error only
    1538 x 580 - 111K
  • felisfelis Posts: 6,525
    That error looks to me as a Connect error not related to the scene file.
    Try to attach the log as a text file.
  • crosswindcrosswind Posts: 10,281
    edited January 2025
    Wrong product GUID shouldn't stop DS from opening a user-facing DUF file... If you were opening that "bad prion 1.duf", the file now locates in your OneDrive folder, you may try copy/move that file to another disk, then open it. Or, open that file with Notepad++ to see if the file is corrupted.
    If the file is compressed, firstly uncompress it via DS > Window > Panes > Batch Convert.
    Post edited by crosswind on
  • I tried that, I guess I have to accept that I can't save the scene, I guess I know what happened, I ended the scene and saved it, but I can't wait and immediately started loading the next one and probably there was a mistake
    Saving process and Opening processing are totally separate routines... they shouldn't bring issues to one another. Have you checked if the file is corrupted ?
    I ever saw a case in the forum, that a folk's hard was damaged to some extent, then some files were not able to be re-opened.
  • How do I find out, please?
    As I said above: Uncompress DUF file firstly  via DS > Window > Panes > Batch Convert. Then open it with Notepad++.
    Or you can attach the DUF file in here if you don't mind. We may help to check.
  • but it's an 18+ scene so
