Poses - hands sinking into fabric
I'm using a pose pack - femine poses for V5. When I use the pack in Daz 4.5 I'm getting the following result. I turned off limits by using control, the dress is colliding and parented with Genesis . Any help would be gratefully appreciated. Thanks
My best guess is that the hands are to close to the body and it can't tell that they should be separated out when it is doing collision. Even tiny body intersections can cause that and they are not always apparent till render.
You might need to move the hands/arms a little bit away from the body. You can also try setting collision OFF for the hands, some times that helps.
Thank you both, I shall try that.
