Blocking Carrara
How do I permanetly block Carrara from down loading. I don't want it and it is taking up space I can use for other things.
Many Thanks
  • Steve KSteve K Posts: 3,431
    I don't understand the problem.  Can you just uninstall Carrara?  I certainly can in windows 10.
  • StezzaStezza Posts: 8,765
    Easiest way is to not download it enlightened
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,164
    I think they are a DIM user who hasn"t looked into the settings to hide stuff they don't want to download and install
  • Richard HaseltineRichard Haseltine Posts: 108,243
    Uninstall it and remove its zip, if you have it (right-click on it in the ready To Instal tab. Then in the ready to Download tab right-click on it and selecty the option to Hide it.
    ahh, yes... DIM is probably the problem. cool
    that app is so aptly named.
    Are you getting the pop-up that offers to install complete packages - Daz Studio and Hexagon, I had forgotten if it includes Carrara. If so uncheck all of them, make sure it isn't set to show automatically (bottom left) and click Accept - that should get rid of it.
    Ah, I see that now.  I don't use DIM, so I missed the problem. blush
  • RuudLRuudL Posts: 226
    From the meager description I can only infer that this is not a Carrara issue. But most likely a DIM issue. Hence my request to move this discussion to a more appropriate forum.
