Dforce simulation: can this be fixed when simulating using the timeline?
JumbotronJumbotron Posts: 279
edited January 2025 in Daz Studio Discussion
Hello,
I have my G8F figure initially at the zero pose. Want to simulate 61 frames. At frame #30 I give the figure the pose you see in the attachment. The problem comes because for reaching that pose the figure literally takes her right leg and makes it cross her body from front to back, like a demon or something. It's actually kinda frightening. See the other attached images to better understand what I'm trying to say (English is not my language), please.
Does this situation have an easy fix other than using another pose or not using the timeline? Thank you.
EDIT: Both the dress and the hair are dforce.
Post edited by Jumbotron on
  • crosswindcrosswind Posts: 10,281
    At the interim frames, check how the thigh rotates and it rotation values... try turning Limits Off on the thigh bone(s).
  • JumbotronJumbotron Posts: 279
    Thank you, crosswind. Next time I run the Studio, I'll try that and then I'll comment how it went here.
    edited January 2025
    It cost me quite a lot of tweaking getting the simulation done. Basically, I had to modify the thigh bone's rotation values for all frames between 8 and 30, both included. Limits for those parameters were off and for several frames the bend value was under the -300 mark. Kind of a pain in the back. But all is good now. Thanks again, crosswind!
