Tesla3DCorp The Master Bedroom
Why is every prop in this set "animated"? There are 151 steps and every prop actually moves, and not in any way I can understand.
Wrong setup...Similar issues happened in some produts from other PAs. They by chance created an animated range in the project scene file before saving figure assets...
You can fill a ticket then delete all key frames except for the frame 0.
this is an issue with that particular PA
one solution explained better than I can
https://www.daz3d.com/forums/discussion/comment/8735176/#Comment_8735176
The existence of that thread and the comments by Tesla made there makes this even worse since the problem continues to happen and the products do not get fixed. I feel worse now for posting about the problem.
