campfire?
dondrawdondraw Posts: 170
i've got beginnings of a scene, 4 buys camping in the fields overnite and something big happens.
i need a small campfire and a light that will illuminate them accordingly. i also need to lower the whole scene so the horizon line is at shoulder level, but all my moves have not accomplisshed that. what control am i not using correctly,one of the ones in the right corner or sometrhing else?
don
  • Richard HaseltineRichard Haseltine Posts: 108,230
    Lowering the camera and tilting it up should raise the implicit horizon line.
    You could use one of the fire and flame VDB products (or a free fire and flame FBX file, I beleive there are a few around - it might be worth checking Combustion's site) but it may also work to use a regular fire model withj its surfaces made emissive (give them a reddish emission colour, or a white colour and a cool temperature value), or just add a few point lights of reddish or yellowish colours in a slightly scattered cluster in the area of the fire.
  • dondrawdondraw Posts: 170
    good ideas thanks. i didn't know about emissive surfaces
    don
    edited January 6
    that sounds easier than i know how to do; i got this but damned if i know how to loser the horizon line. advice please.
    don
    2616 x 1004 - 1M
    and this but how tilt camera cant find control for that
    1774 x 1030 - 475K
    Since you seem to be looking through your camera (the View picker at top-right, which currently says Camera) you can just use the View controls - right-mouse drag on the orbit/rotate button (the one with a curved arrow going around a sphere) in an upward direction.
    thanks for the assist, richard. works. Onward!
    don
  • FishtalesFishtales Posts: 6,212
    Go to Render Settings/Environment/Dome Orientation Y and lower it using Negative numbers until it disappears e.g -30, -50 etc.. You can also scroll down to Horizon Height and use Negative numbers there, which ever looks best.
