Weird thumb bend on G9
BoorsmanBoorsman Posts: 281
I have a character I created for G9.  Whenever I bend his thumb 3 on left or right hand, it bends sideways and not down. Whenever I pose a fresh G9 thumb, it doesn't happen.
Post edited by Boorsman on
  • lilweeplilweep Posts: 2,746
    edited November 2024
    Did you use the automatic  'Adjust rigging to shape' option? You may have chosen to adjust 'orientation' in the options dialogue. The automated process for adjusting orientation is liable to cause issues for fingers, toes, eyes, so usually good idea to do the rigging adjustments automatically using the default settings. Then, as a next step, do the orientation adjustments manually where needed, e.g., on the fingers and toes, eyes.
    Post edited by lilweep on
  • BoorsmanBoorsman Posts: 281
    I did use "adjust rigging to shape" when I discovered this issue.  I didn't notice it at all until I applied a pose for G9 to my character.  I don't think it exsisted before now.  I would upload an image, but whenever I try, it just keeps saying Uploading.  I even checked the file size, and its at 9mb.
    When you say you "created a character", what did you mean? You dialled in different presets, or you loaded via morph loader pro.  My previous message was assuming you had loaded new character via morph loader pro and adjusted rigging yourself, but now i realise you may have just been creating a custom character from presets...
    I would suggest: Load fresh G9.  Test the faulty bone (the thumb) by rotating it on each rotation axis.  Is it faulty even without your character preset dialled in? Or is it faulty only on specific character?
    If faulty on specific character,  then one of  the character morphs being used for that character may have incorrect rigging orientation. Identify which individual morph causes issue. Then with that morph loaded in you can adjust the orientation of the bones manually with the Joint Editor tool selected, in the Tool Options pane.   If you then want to re-do the ERC freeze process that links the rigging to your morph, you can do the following:Perhaps easiest way is in Edit Mode, right click and choose the ERC Bake (Delta add...etc) option. That will unlink the ERC properties, and you can redo ERC Freeze. And can re-save modifier asset.
    If that last step about ERC freeze and saving modifier asset is above your head, then perhaps just dont use the faulty morph.
    I created this character from dialing different morphs from different products I bought from here.  I created him in 2007 with M4 and K4 morphs.  Since then I have been updating him to the newest Genesis.  I used Figure Converter to convert him from G8M to G9 and have been making small adjustments.  I have looked at all the morphs used, and none seem to be the issue.  I even saved tthe shape and applied it to a frsh G9, and there is no issue.  However, after applying the shape to a new G9, the face is by the tiniest bit not quite right.  Something just seems off.
  • sirnamedmarksirnamedmark Posts: 21
    edited January 3
    I ran into a similar situation myself! I had created a custom morph using tons of dials. Then i had used morph loader pro to import the single morph... I used the adjust rigging to shape function after loading the morph..and i had clicked the adjust orientation tick box..  (I didnt realize at that time that it had messed up the thumbs only.. lol.) So long story short.. i ended up loading a 2nd character into the scene (a base G9) and then selected it first in the scene tab and then held the ctrl button on the keyboard and selected my character that had the weird thumb issue. Then I went up to the edit menu>figure>rigging> and selected the "Transfer Rigging (Figure Space)". Then I just did the Adjust rigging to shape procedure on the character with the messed up thumb. Seems to have fixed the issue! :) Should mention that i use the premier version of the software. Im not sure if thats a standard feature or not.
    Post edited by sirnamedmark on
    if "adjust rigging to shape" messes up the orientation of the bones on the thumbs, eyes, toes (as it is prone to do), you can manually fix the orientation of the bones with the Joint Editor tool selected in the Tool Settings tab.
  • Richard HaseltineRichard Haseltine Posts: 108,084
    Baking all those morphs down to a single morph is not a good idea - you have already run into one drawback, having to redo the rigging adjustment (and you can't expect the Adjust rigging to Shape to do all of it) but you have also lost all the links to corrective morphs that handle things like allowing the eyes to close without overlap. It is vastly better to create a new controller and then use ERC Freeze to make that drive the other shapes, that way you get a single control for your character and don't have to redo any of the other work.
  • crosswindcrosswind Posts: 9,570
    edited January 3
    You didn't have to do that... If you Adjusted Rigging to Shape with wrong settings (no need to adjust orientation...), you could simply Ctrl + Z then redo. If undo was no possible, with Joint Editor, Restore Figure Rigging and redo Adjust Rigging to Shape.
    BTW, those are not tied to Premier but DS standard features.
    Post edited by crosswind on
  • Lil ~ Ah, good to know! I will have to research how to use that tool. :) Richard ~ You're probably right. I had read that combining the morphs would lessen load times though so I had given it a shot. By controller, do you mean dial? I Will also have to research that. Cross~ Yea, this particular character had the error saved into the morph it seems. I will have to look into the restore figure rigging. Thanks yall!
  • AH! Yall are great! I tried the joint editor method! It was literally as easy as putting " - " in front of the X rotation numbers for all 3 sections of the thumb. :)
    2895 x 1577 - 1M
    2870 x 1658 - 1M
    2866 x 1648 - 1M
