change color of wardrobe
i'm using four characters through a complex plot in which they should change clothes occasionally. i have these 2 in sleeveless t shirts that are white. how may i change color of shirts?
don
    Select the clothing in the Scene pane and under the Surfaces pane it will list the surface areas for it. Find the baseColor and there you can apply any colour you like. Alternatively, if you have some material shaders (e.g. a cotton shader) you can apply those to the surface(s).
  • crosswindcrosswind Posts: 10,276
    And are there any material presets within the product of sleeveless shirts. If there're, check and select the ones you like.
    BTW, if you apply white color on these garments, try tweaking the color in Base Color e.g. giving it a light grey, and add some Diffuse Roughness... now they're too glaring.
