Collective3d™ Create-A-Room FREE GIVEAWAY contest [COMMERCIAL]!
From now until September 14th, 2015, Collective3d™ is giving away 1 FREE copy of the upcoming Create-A-Room set for every 100 likes to the contest post on the Collective3d Facebook page!
Be the first to receive this new set, before its availability to the general public!
Create-A-Room Base Set includes 5 walls with 5 color options, 5 trim options, and 4 position options per wall, 1 floor mesh with 5 color options, 1 ceiling mesh with 2 color options, two scene-illuminating ceiling light fixtures with ON and OFF material options, fixtures including a wall switch, electrical outlet, and heat register, plus a bonus oil painting of Black Bear, the Worst Best Dog Who Ever Lived™.  The Create-A-Room project is fully expandable, and future releases will include additionall walls, ceilings, furnishings, decorations, and more.
You can find the contest post at the Collective3d™ Facebook page by following this link:
http://www.facebook.com/collective3d
In order to be eligible to win, you must LIKE the contest post by 11:59pm Eastern Time on September 14th, 2015.  Full details are provided in the contest post!
«1
  • JOdelJOdel Posts: 6,317
    What a nice set of room components! Not limited to ultra modern styles, either.
    I gather that one can use whatever walls in whatever arrangement one chooses. Is there a wall with a door?
    Sorry, I don't do Facebook. Will wait to see it in a store.
  • KeryaKerya Posts: 10,943
    Doors? Please?
  • Kerya said:
    Doors? Please?
    Second that - I don't see a point to a room with no doors.
  • WilmapWilmap Posts: 2,917
    I don't use Facebook either, so that lets me out of the contest too!!!!
  • looks good and looked at your other products some iteresting things there you should mention the name of your store here btw as I tried to look up vendors Collective3D with no luck, luckily you have on your facebook page a link to your store here though many may not see it and know your vendor name here is NFXstudios http://www.daz3d.com/nfxstudios
    you should mention that here so everyone can check out your other stuff and get more interest in your products
    A whole set with doors are coming in one of the first few expansions.  Interior passage doors, exterior doors with and without sidelights, sliding doors, french doors, bifold doors, etc.
    And yes, walls can be arranged in any position.  Each of the 6 walls has 4 default positions that can be loaded:  Front, Left, Right, and Back.  Since Daz Studio doesn't have vertex snapping (at least that I know of) that was the best way to insure that the walls all lined up with each other perfectly in every position.  There are global material presets individually for wall color and each level of trim (window casing, baseboard, chair rail, wainscot batten, wainscot panel) as well as an OFF setting for each piece of trim.
    Funny you should mention that... I was literally adding that to my forum signature as you were typing.  Thanks for reminding me psychically!
    Good to hear about the doors - and thanks for the position helpers!
    The Align tab has only old documentation where the pictures are lost ...
    http://docs.daz3d.com/doku.php/artzone/pub/software/align_ace/start
    http://docs.daz3d.com/doku.php/artzone/pub/tutorials/dazstudio/studio-models08
    The Align tab will get you most of the way there, but it's not as robust as the alignment features in other 3d software.  Most of the other things in the set will require the use of Align to get them into position.  But I felt it was important to make sure the walls were always lined up perfectly to avoid seams!
  • your welcome it helps gain interest in your new product if customers can see your previous products and quality of them. Like the windows looks like you can get some nice lighting through the scene that way just like in real life the more windows the better the lighting via natural light be good for a photo studio type setting
  • The Create A Room Base Set is now in testing.  Head on over and join in the contest if you haven't already!
  • L'AdairL'Adair Posts: 9,479
    I'm glad I went back to see how your "Likes" were doing, as somehow the first time I missed the bit about Liking the contest post. I Liked the page instead. Now I've Liked the post. Shared it on FB, and tweeted the FB link, too.
    The set looks really good, and I love the fact there will be expansions sets. Your Farmhouse is one of my favorite sets, so I'm really looking forward to Create-A-Room.
  • Wow, good thing you decided to go back.  Thanks for the share!
    5 days left, for those who haven't entered yet.  Head on over and throw in your hat!
  • 4 days remaining in the contest!  Still plenty of time to get in on the action!
  • 3 days to go!  Winner(s) will be announced the morning of 9/15/15!
  • AtiAti Posts: 9,185
    I'm feeling exctied. :)
  • 2 Days!  Get on over and like the contest post if you haven't already!
  • Last call!  A little over 30 hours left until the contest ends!
  • Either way, I'm looking forward to checking out the mesh to see how you put it together.
    I think I solved a lot of the design issues I encountered as well as possible, given that there are certain limitations with the Daz software (like lack of vertex snapping, etc).  Each wall has 4 position presets, so you can load a wall into perfect alignment and rotation on all 4 sides of the floor.  All the trim is part of the mesh, and is hidden or shown through material presets.  This saves the user from having to try lining up tiny trim pieces.  Each wall can then be moved, if desired, to create narrower rooms or passages.  And the unwraps for each of the main pieces (walls, floor, ceiling) are fairly simple and high res, so it's also pretty easy to change colors or add additional tile or wood options.  The main wall/ceiling color is off-white, which is also easy to color with just the diffuse slider.
    Hopefully you all will agree about the ease of use.
  • DarkSpartanDarkSpartan Posts: 1,096
    edited September 2015
    We shall see, certainly. But then I suppose it'll depend on how long it takes me to lay hands on a copy. Maybe make some chintzy wallpaper or something.
    Post edited by DarkSpartan on
  • Less than 10 hours to go!  Last chance to get in on the drawing.  Winner will be drawn tonight at midnight, and announced tomorrow morning around 9am eastern!
    Good luck to everyone who's entered so far!
  • The winner has been announced in the contest post on the Collective3d Facebook page.  Congratulations, and check the "other" tab of your Facebook inbox!
    Congratulations to the winner! :)
    Will you have such contests in the future, too?
    Yes, I'm planning to, for sure.  If not for every new set, at least for the "major" ones.
    Sounds good. :) My luck will surely come at some point. :)
    Congrats to the winner. I'm envious. laugh
    Now... When will the rest of us be able to get our hands on it? LOL
    (I checked the DAZ store, and had to search to find you. Apparently DAZ has changed your vendor name from nfxstudios to Collective3d... http://www.daz3d.com/collective3d ...  Yay!)
    Yep, had the vendor name changed to reduce confusion.  NFXstudios was my business name for many years, but when I got together with the original crew who was supposed to work on the Blue Collar series with me, they wanted to come up with their own brand.  Then they stopped working, and I was stuck with my branding halfway between NFXstudios and Collective3d.  Decided to just go with Collective3d.
    As to when Create A Room will be available to the general public... that's up to the Powers That Be!
  • The Base Set is now available!
  • scathascatha Posts: 756
    Why do people keep thinking everyone uses facebook?
