Lengthen Pant Legs of Jeans
n.aspros123n.aspros123 Posts: 337
edited December 2024 in New Users
Haven't used Hexagon much but was wondering if it could be used to lengthen the pant length of some jeans?
Is the character exported to Hexagon in A-pose or in a pose like below?
Is anything else need for transferring and receiving?
I understand that Hexagon make a morph slider in Daz to adjust the parameter, is that correct?
Post edited by n.aspros123 on
  • crosswindcrosswind Posts: 9,739
    No adjustment morph on the jeans ? If so.... I remember you have Mesh Grabber 3.0 correct ?  You can easily fix it in DS:
    1) Alt Shift + G to activate Geometry Editor, with Polygon Selection Type + Marquee Selection Mode, select the lower part of the jeans (ss1).
    2) Alt Shift +E to activate Mesh Graber, drag and push until you're satisfied with the result (ss2). The trick is while dragging and pushing, shrink the polygon selection by pressing Ctrl + - (minus on num pad) and Ctrl + Mid-Mouse button to shrink the mesh grabber gizmo... to assure the mesh looks good, i.e. stretching no more no less..
    2560 x 1392 - 1M
    2560 x 1392 - 1M
    Better do it when the figure is in A-pose... then if the jeans are fully symmetrical, you can tweak both sides at the same time (ss1 ~ 2.)
    I don't know Hexagon but just use Blender. It's also very easy to adjust the length in Blender by using Grab brush + Symmetry. Then import as an adjustment morph. (ss 3 ~ 6)
    2560 x 1392 - 2M
    2560 x 1392 - 2M
    2015 x 1294 - 740K
    2560 x 1392 - 1M
    2016 x 1289 - 882K
    2017 x 1292 - 872K
    Post edited by crosswind on
  • @crosswind Does the character and jeans need to be exported to Blender from Daz?
    Last time I had troubles exporting from Blender and importing to Daz. The clothes went haywire.
    https://www.daz3d.com/forums/discussion/695911/clothing-morph-applies-weirdly-after-importing-from-blender-straps-look-weird-too#latest
    If you want to make it with Blender, yes, you need to export them both.
    As for the export / import settings, I gave the correct ones in the above thread. If you still cannot make it, check this video: https://mega.nz/file/qeg10B5S#YYCh1mmeKcvL4IprIt0UJAP6eJsOZUIm4MRgaw0zU2M
    How is the Symmetry function used in conjunction with the Grab tool in Blender?  @crosswind
    Check the above video... starting from 1:15 ~~
  • @crosswind  Check your gmail please.
  • @crosswind
    After making the adjustments and morph slider.
    What do I save the jeans as for future use?
  • Hellkitty742Hellkitty742 Posts: 68
    as a woman those pants would never be on me either they fit or my body is wrong sorry
    Post edited by Hellkitty742 on
    n.aspros123 said:
    @crosswind
    Wearable Presets ...
  • n.aspros123n.aspros123 Posts: 337
    edited January 2025
    crosswind said:
    n.aspros123 said:
    @crosswind
    Thanks for your replies.
    I used @crosswind suggestion and instructions and used Mesh Grabber with the first jeans. I lengthened the pant legs of the jeans. I also made a morph adjustment. I also fixed some poke through by dragging pulling the jeans out to cover the skin. See attached pics. Thank you.
    1402 x 936 - 137K
    1394 x 922 - 133K
