Ghost light is broken
Using daz 4.23 version which has an inbuilt ghost light feature. I watched the tutorial on how to properly use it. it works perfectly well at first. It doesn't show up in render and is functioning as a light source. But the moment I reopen the scene with ghost light it's totally broken. I can't make it invisible in render. Only fix I can find is to create that ghost light from scratch and render it without reopening the scene but that's not an option for me. Any way I can fix it?
My quick test scene seems to work, having closed DS, restarted, and loaded the scene
yea tried yours and it works fine but mine is still broken. Maybe u did something different? How do you create ghost lights?
I ran the Create Advanced Iray Node Settings script and created both the Visible to Primary Rays and Ghost Light factor properties, you should be able to see them under Display in the Parameters pane for the plane.
