Genesis 2 Figures in Iray & 3Delight - SOLVED
I've just noticed that, when rendered in Iray, FW Travis for Darius 6 appears discoloured. (Note his skull and hand in the pic attached.) When rendered in 3Delight, the discoloration is not apparent. Could it be that Genesis 2 figures (some if not all) are not compatible with Iray or could this discoloration be caused by some other flaw? Thanks to one and all.
Post edited by contedesfees on
G2 Darius and FW Travis products do not have iray material presets but just AoA presets for 3DL. But the issue you have is not related to material preset but the settings on figure's surfaces.
Check tiling settings on Face, Hands and any other problematic surfaces, reset them to 1.
Thanks so much, crosswind. It is appreciated.
No problem !
