cannot access saved files and saved subscenes from program.
Opened up Daz the other day and the program somehow changed or updated. When I try to access a scene or subset I am now getting an error that file cannot be found.  How do I correct this? - I can go to the file locatiion and drag and drop and it will open but I can't do it from within the daz program -  I just see this now and I'm not understanding why.  It no longer seems I can save a subset or scene.  If it's a path issue where do I find the specific path entry in preferences for the scenes and subset to set it correctly?
  • Are you sure it is still in a content directory in the correct relative location - all of the database drive views depend on that. If the content directory is no longer active, or if any of the folder names or location between it and the files have changed then loading will fail.
  • barbultbarbult Posts: 26,645
    Some people have this kind of problem if their content is on an external drive, and it mounts with a different drive letter.
