shape of toes is weird
I've tried adjust rigging to shape, but it's still weird. What's the problem?
I need your help. Thank you
Some more information would have been helpful. Is that the default figure, or did you do something to it? do you have a morph loaded which is causing the distortion. Does that issue happen at rest or only in certain poses?
When loading the default figure, if the distortion is present, check the Currently Used filter under the Paramaters tab. (Ensure show HIdden Properties is selected). Look through the currently active morphs to find the culprit.
Moved to Techncial Help as it is a content rather than a Daz Studio issue.
Which figure is it, in addition to lilweep's questions>
