[Released] Bone Minion for Millennium Horse Poses [Commercial]
RiverSoft Art
Quickly expand your library of poses for DAZ Horse 2, DAZ Horse 3, HiveWire Horse and LoREZ Horse 2! With Bone Minion, you can directly use poses for Millennium Horse for other Horse figures. Your Bone Minion will do the hard work for you by acting as a bone "catcher" for a pose and then transferring (and converting if necessary) the pose to its parent DAZ Horse 2, DAZ Horse 3, HiveWire Horse or LoREZ Horse 2.* Simply load the Bone Minion on your DAZ Horse 2, DAZ Horse 3, HiveWire Horse, or LoREZ Horse 2, select the Bone Minion, and start applying poses!
- On the fly conversion of Millennium Horse poses to DAZ Horse 2
- On the fly conversion of Millennium Horse poses to DAZ Horse 3
- On the fly conversion of Millennium Horse poses to HiveWire Horse
- On the fly conversion of Millennium Horse poses to LoREZ Horse 2
- Works with Millennium Horse full poses, partial poses*, hierarchical poses**, Horse and Rider hierarchical poses***, and even AniBlocks!
- Automatically applies full poses when they are loaded*
- Supports pose properties (using the Create Heavyweight Bone Minion script)
Note that converted poses (and especially props if they are hierarchical poses) may not be perfect and may require tweaking. Facial Bones (i.e., expressions) except for the eyes are not transferred.
* Any pose that sets the hip of the Bone Minion will be automatically converted on the fly and applied to the target figure. The Apply Changes script can be used to transfer any pose (including partial poses) on the Bone Minion to its target figure.
** Hierarchical poses with props require the props loaded on both the Bone Minion and the target figure. The prop will be properly rotated for the pose but may need to be manually translated to the correct location. Millennium Horse has different bone names than other Horse figures. You will need to manually move the prop to the correct bone on the Target Figure.
*** For Horse and Rider Poses, you must have the correct figure Bone Minion product installed (i.e., if the hierarchical pose is for Millennium Horse and Genesis 2 Female, you must have the Millennium Horse Bone Minion and the Genesis 2 Female Bone Minion), the bone minions must set up as the hierarchical pose expects (e.g., if the Genesis 2 Female is supposed to be on the Pelvis bone of the Millennium Horse, the Genesis 2 Female Bone Minion must be on the Pelvis bone of the Millennium Horse Bone Minion), and the Target Figure of the Figure Bone Minion must be set to your Target Figure.
Horse Skeleton Model in Main Promo is by Diego Luján García (Creative Commons Attribution) and is available at Horse Skeleton. No changes were made.
And it is released!
Thank you very much!!
You're welcome! Enjoy!
M'boy, m'boy! I dared not hope that this pack was forthcoming, but here it is, and at a pittance, no less! Your kindness is boundless, as is my gratitude. Thank you so very much.
I have a very ill pet and meant to thank you earlier, but time did not allow it. I think this was very generous of you. Thank you so much. Also, I was certian I bought your Bone Minion for Daz Horse 2 but it appears I didn't. Lo and behold it's on sale tonight and in my cart. Thanks again.
You're welcome! Thanks for the support!
