How to make a knot in Marvelous Designer?
My knot is always loose, not firm or tight.
Do you have suggestion how to make it firm?
  • crosswindcrosswind Posts: 9,637
    edited December 2024
     Yes, just manually tie the knot by adding Pins when dragging the pattern in 3D viewport... Then the knot can be much tighter.
    sort of this example https://www.daz3d.com/forums/discussion/comment/8858346/#Comment_8858346
    As the example shown in the screenshots, the trick is : drag to tie the knot tighter and Pin, then drag and Pin ~~ till you're satisfied with it. Then finetune the final result.
    1065 x 1305 - 485K
    1065 x 1305 - 478K
    Post edited by crosswind on
  • JamesJames Posts: 1,175
    I tried that method, But as soon as it become tighter, it went through itself.
  • lilweeplilweep Posts: 2,753
    does making PD smaller help?  It will increase the self-colision
    There are videos on youtube for making knots.
    You can also buy pre-made knots for MD on artstation.
    The MD discord is here: https://discord.gg/W8NmgxwY
    As long as you Pin the mesh well, you can tie a good knot. I ever learnt the tricks from this tutorial : https://youtu.be/BxMLr3wUmF8?si=8ImdJ5pCnrErHPDG
