SOLVED VDB Clouds behavior in 4.15.0.14pb
StratDragonStratDragon Posts: 3,278
edited December 2024 in Daz Studio Discussion
Can anyone confirm that the VDB clouds work in 4.15.0.14pb? I tried with the Nvidia drivers 566.14 and 566.36 which is the most current and they render incorrectly for me
Post edited by StratDragon on
  • crosswindcrosswind Posts: 9,743
    IIRC, starting from DS 4.20, OpenVDB MDL shader was update to latest version. If you ever updated Default Resources package, I'm afraid you're not able to make it work with 4.15.
    You can simply install a DS 4.23 Public Build version, VDB should work with it.
  • StratDragonStratDragon Posts: 3,278
    crosswind said:
    ...You can simply install a DS 4.23 Public Build version, VDB should work with it.
    Solved!
