Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Not this persona
But thanks for asking. I kept my gaming/humor personality completely detached from my pinup art persona. My pinup personality has only rendered a few turntables and a couple of dances. If you check my deviant art and search dance you can see the only animation I have on file. I had a few more animations on my dA page but I deleted them since they were just showing off how dynamic clothes suffer wardrobe malfunctions when women move.
http://larsmidnatt.deviantart.com/gallery/53477762/360-Views
But if I'm lucky I should have something neato that I can share in a month and a half. And I do mean neato! Top secret cause I don't like to jinx things. If things work out as planned I'll be sure to share in the commons(will be appropriate for all ages
Most of my animation experience comes from working on games (not with daz tools or content). But recently I did get a GDL from Dazzler Studios so might have been spending time on that :)
I totally understand
. I look forward to when you do get some posted I love to watch animation. I'm not a critic, I'm a sit back and watch and learn type person. that is why I asked. because you really sound like you know your stuff when working with daz and animation. I am still trying to figure it out myself I'm such a slow learner..Ha Ha ! I use to put all my efforts into poser animation, But the tecnology has dirfted apart from daz and poser so much that i had to make a choice on which program I was going to invest my time in and for me Daz was my better option. I love to tell stories so I try my best to use daz to tell them in animation.
"I don't have a render-farm to animate with IRay in Daz..."
IRay is not in Daz, it is just accessed through Daz, and included with it. It is its own thing. However, the issue is IRay, not Daz... You can render on a train, render on a plain, render in the rain, render while in pain... It will take the same amount of time to render, with IRay, no matter where you are, or what you use, or when you use it.
What you need to do, is find "animation shortcuts", to speed-up your process and still get the desired output. If you are trying to make it look like a million-dollar movie, even only a few seconds of a million-dollar movie... You will need a million-dollar render-farm to do it.
However, there are MANY "Tricks", to speed-up production. Even within DAZ.
1: Ignore your "dreams of grandeur", do only what NEEDS to be done, to get the point across. (You don't need a billion people walking around in a wide-screen-shot, with thousands of objects all over. Zoom-in, focus on the target, and isolate what you actually "Need".)
2: Details... The models, most of them now, come default on "High Detail"... EG, Lots and Lots of time-killing triangles. If your model is only going to be 500 pixels tall, you don't need 50,000 triangles to precisely draw a hand-full of pixels, when 5,000 would be more than plenty. (Seeing as the maps are 2048x2048, or 1024x1024, or 512x512 and all are overkill, unless you are zooming-in on a hair-pore in HD.
3: Swap-out the eye-images for a solid color. The eyes will be only a pixel, in 99.9% of instances, or less than a pixel. Don't waste time rendering a 1024x1024 image reduced into a single pixel.
4: Pre-render static scenes and save them as an image. Put the image on a flat-wall and render the actor and some scenery components in actual 3D, in front of it. (Use the "Render-floor" option, which should be ON, by default. It will draw the shadows as if the actor is standing on the scenery. Also, there is a real neat VRML scenery plugin that even has 3D layers, all setup for prefab scenes. You can make your own too, but that is another story.) You will quadruple, or more... your animation rendering speed.
5: Prefab animations, already mentioned... There is another one called "Alive" or something like that. It adds-in random and repeatable auto-animations for many actions... Blinking, Breathing, Glancing around, Head gestures, Idle Fidgeting, etc... (Not sure if it works with Animate2 or the new DAZ. But you could load it in an older version, get the animations, save them, and load them in the new Daz.)
6: Faster rendering engines... This is not an easy one... Few, if any, are setup for Daz, and fewer setup for IRay materials. Look-up Vray vs Octane Vs ... whatever... Octane is the fastest and best looking. However, I am not sure if the render-farm files that daz makes, can be read by Octane. (With similar output, since it uses IRay materials, intended to be sent to an IRay farm.)
7: Recycled animations, that have been previously rendered... Either use them directly, showing cuts of the same video, or include the video-clips into the new render, as scenery background, as distant views, as... whatever... (Have to be creative here.)
That's all I have for now... Good luck... Google and youtube for "Animation tricks", shortcuts, tips, speed-boosts, rendering tricks... etc... (Oh, and include Daz in the search a few times. There is a few things Daz related.)
Actually, Star-Wars did this a LOT... The latest movies didn't even have "sets", they were all 100% bluescreen and "render-standins", like the "Matrix"...
They rendered a VRML scenery of every area, once... Then just projected that onto the background after rendering the other isolated individual objects of the foreground and "model actors", or real actors sometimes...
Again, you don't have to render everything in the scenery all at once... Using the tricks above. (Just be sure to save your lighting. You want that to be persistant to the stage, no matter what tricks you use.)
I want this!
Other rendering engines...
there are Alive packages for Animate. They are neato.
The render looks pretty grainy on my screen, but on YouTube SD the graininess just goes away in the blur.
Tring that actually is one solution I use, render to a larger size but lesser settings than what you are going to composite it as, the fireflies/graininess disappears a lot of the time
there is a g3F lip sync dmc on the forum somewhere made by a kind soul in notepad I will try and find it, I made one myself but his is better.
I'm very new to this. I posted a few render tests to YouTube, which I reference earlier. I'm working up to my first animation. I've found some good, cheap sources for very nice sound effect files. I need to find some sources of free music. I've found some high quality computer generated voices for "place holder", dialogue. If it gets somewhat finished I might contract with a voice actor or two online to do live dialogue. I need a lot of things! I have a plan for my first animation. it will be Sci Fi themed. A ship boarding. But theres a lot of work between here and there - as you well know. I will keep you up on my progress if you're interested.
I been looking for an animation thread for days. I'm making a music video with some video vixen type girls in heels dancing. When I dress the characters and apply the foot pose they look fine in the t-pose but when I apply the dance animation the feet get all out of wack. I have applied the high heel rotation offset in Animate to the maximum but when I apply the dance aniblock, she sinks back down and she just looks...weird. The dance is fine barefoot. Am I doing something wrong or can they just not dance in heels? The moves I'm using are the Pop Dance - Girl Style 1
you probably want to make an offset aniblock for the heel pose. Same idea as doing an offset from V4 to Genesis.
You know I never had any luck with that offset pose for v4 to genesis. It worked for the first frame and went back to normal feet after that. So I just use posemaster to convert poses. But how do you make an offset pose and how to you place it in the timeline? Do you just extend it to the length of the animation on a sub track or do you place multiple offset poses the length of the main aniblock animation track
just one pose block, can be one frame. do you use Animate and not Animate light? (honestly not sure it matters, but I have the full version).
Is the pose block set to additive? Did you add anything else to that layer? I leave the adjustment block on it's own layer. Works fine for me.
I use the full version of animate. So you're saying add one offset pose block per frame? I'm not sure how to set the block to additive. Also if by layer you mean the sub track where I added the off set block, no I don't add anything else to that track but the off set block.
You add a subtrack, and put the offset pose block there once. Like this:
It seems to already add as additive to me by default. You can check the icon at the left of the subtrack. If it's a +, then it's additive. If it's something else, then doubleclick on the sign, and choose "Add":
(I've only bought Animate2 yesterday, so I'm a total newbie. I, too, have just been following what larsmidnatt suggested. :) )
No you don't need the offset per frame, just once.
I've noticed that if you stay away from rendering directly to a quicktime movie, and instead use TIFF image series at 24 fps, you see a better render time. Then what I do is import these individual frames into Adobe Premiere and make each frame 1/24 sec. Then I save and export as an Apple ProRes 422 HQ 10bit file so that I can do some editing in post. Works well. The direct to movie format compression I find takes 25-30% longer due to software compression.
never render to video. always render to image series. if the video file corrupts, daz stops half way through and crashes, etc etc. So much can go wrong with video. Unless its a really fast render you mean to trash later.
Render to stills.
Oh thanks you all are so helpful. Daz has one of the best forums around. Ati2 and larsmidnatt thanks a bunch.
Thanks, Ella
