G2F renders with a hole in her face
Has anyone any idea why G2F, dressed in IH Kang's Waitress Uniform and posed with a V6 pose from DM's Sensual Olympia, consistently renders with a hole in her face?
  • if it;s a combination of all those things, maybe try eliminating each individually to find outwhat one is causing it
    the outfit, the pose or the hair
    my money is on the hair having a hair cap that's causing it and has a shader setting making it visible in render such as glossy reflectivity
  • SimonJMSimonJM Posts: 6,067
    Also, take a look at the Horizontal and Vertical Tiling values for the surface(s), they should be 1
  • contedesfeescontedesfees Posts: 299
    edited December 2024
    Thanks to WendyLuvsCatz and SimonJM. I'll experiment and check the tiling values. DS has so many nooks and crannies, it's sometimes hard to tell where first to look for the source of a problem.
    I started with the hair and took G2F to her "natural state," discovering that the holes in her face was the tip of the iceberg. It's one for Holmes and I'm a Watson.
    Post edited by contedesfees on
