Hair 3D print
xavierator
in The Commons
Dear,
Can the Daz hairs be 3D printed ?
I tried some samples but the hair is never printed
Thanks, Xavi
I believe there were some hair created with the idea of being printed at the shop, back when printing licenses where implemented. but I don't have an example, Most hairs consist of layers without depth (if not strand based which is no good for printing either.
You might have luck with some of the toon hairs
Yes, toon hair seem a better option for 3D printing.
A few were suggested here: https://www.daz3d.com/forums/discussion/710241/3d-printable-hair
There used to be a plugin that would upload the model, process it for 20 minutes, then send back a printable STL. But the company for that discontinued the service.
What you can do is export as an obj, then open it up in a model editor like Meshmixer. Select the faces for the hair geometry, then have it extrude them around 0.2mm. Then they become solid object that can be printed. It takes a lot of futzing to clean it up though.
Thanks for these information
I will try it
I used the unified skin feature in Zbrush for the few things I printed before DRM not recognising thier own filament cartridges made my DaVinci printer useless
