Selecting multiple properties at once?
DrGonzo62DrGonzo62 Posts: 387
edited November 2024 in Daz Studio Discussion
Hi,
Is there a reliable way to select several properties at the same time, to add them all to Favorites for example?
I've tried dragging, or holding CTRL or ALT when selecting them, but that mostly doesn't work.
Is there a better way to do that?
Thanks!
Post edited by DrGonzo62 on
  • barbultbarbult Posts: 26,585
    From the Parameters context menu (hamburger menu) select Edit Mode. Then you can Ctrl click to select multiple properties.Then right click in the parameters list and select Favorites>Add Selected Properties to Favorites. Exit Edit Mode when you are done, by unselecting it in the context menu again.
    595 x 624 - 98K
    576 x 666 - 100K
  • Yes, that works. Thanks! yes
