UV maps from Hexagon to Daz??
I am learning Hexagon and right now I am doing UV maps practice. I made a simple cube with an UV map that gives different colors for each face of the cube.
I am trying to port it into Daz.
So far I have loaded the cube itself into daz, by importing.
The problem is that whenever I load the .obj file into Daz, itrenders as a "white figure", and I can't figure out how to load the UV patterns.
the Edit > Object/figure > load UV set has allowed me to load the figure's .obj export from hexagon, and it shows in the "surfaces > geometry > UV Maps" pane, but so far changing it to the uploaded items does nothing.
What piece of the puzzle am I missing?
Attached a screencap of what I'm getting, in case it helps.
Have you actually a plied a map? E.g. by draging from a folder onto the Base Colour property in the Surfaces pane. There is also a UV Drawstyle for the Viewport, which by default shows the selected object(s)'s selected surface(s) - that's the button next to the camera/view picker in the top-right corner by default, although in the UV View the cotnrols are docked at the top and the switched are then on the left.
This was it!!! You saved my day, buddy!! I'd give you a like if there was such a functin in these forums!
This video also helped me find out the buttons you were telling me to pull.
https://www.youtube.com/watch?v=rkzblAActBE
Thnak you so much!!
