How to consolidate Morph
Hello everyone.
I am using multiple character morphs to create original characters. However, if I use too many morphs, the Current Used column becomes complicated.
Is there any way to combine multiple morphs into one?
Thank you in advance.
  • lilweeplilweep Posts: 2,792
    you can export (at base res) and import (via morph loader pro) to bake the morph but:
    1. it will lose all links (to custom JCMs, rigging)
    2. you will need to re-rig, re-link, and save out new morph
    Or you can make CTRL property and link all the properties under that control, but then that also will still cause clutter in your Currently Used filter.
  • Thank you lilweep .
    Thanks to you I got to Jay's tutorial!
