Legacy Uvs for Genesis 9 ISSUE!!
Product: https://www.daz3d.com/legacy-uvs-for-genesis-9-genesis-3-8-and-81-male
Anyone know how to fix this?
Here's the steps I did:
I apply this 'prepare Gen 9' [image SS1] to the base and then applied the mats (Genesis 8 male) [image SS2]  then click the Apply Gen 8 male UVs [image SS3]
and this is the result I got [image SS4]
I followed this vid but still got it wrong. In the video, it was fixed when he clicked the apply genesis .. but mine didn't.
https://youtu.be/JJyPFAeqjVE
  • You need to apply the original Genesis 8 materials to the GeoGrafts added by the Prepare preset - they are not, as fart as I know, copied across automatically.
  • ObsiObsi Posts: 22
    Thank you so much. that fixed it
  • gminx2018gminx2018 Posts: 6
    edited January 2025
    I'm facing a similar issue and am not sure what this means. Are you referring to the heirarchical preset in the Genesis 8 Essentials? Additionally, are you suggesting the geografts are selected individually to load said materials? The tutorial mentioned is a bit misleading so I'm comparing the fix here with the cautions there in and in the tool documentation and becoming more and more confused.
  • crosswindcrosswind Posts: 9,618
    If there're H.Material Presets in G8 character product, you need to select figure's root node, anatomies, as well as the geo-graft node before loading H.Material Presets. Preparation Step 1 just does that selection for you. (ss1) After running step 1, you can directly load H.Material Preset from G8.
    If there's no H.Material Preset but just Material Presets, you have to apply the Material Preset separately for anotomies, i.e. Material Presets only work on figure's root node and geo-graft node.
    2560 x 1392 - 592K
  • Please crop the image higher - there is no need to show the groin area.
    I am assuming that is a GeoGraft for the breasts? It looks as if the wrong map is being applied, but why and what should be applied I do not know - it isn't even clear where the graft boundaries lie.
  • fibykenfibyken Posts: 46
    edited August 2025
    I believe I may be experiencing the same issue you encountered, you share the steps that corrected it for you?  I simply cannot figure it out.  :)
