Can no longer add dForce Dynamic Surface Modifier to an object?
Gen3dxGen3dx Posts: 21
edited November 2024 in The Commons
I used to be able select an object in the Scene hierarchy, and via the Edit > Geometry menu be given an option to "Add dForce Modifier: Dynamic Surface"
But now the Edit > Geometry menu no longer has this option.
Did something change in a recent update to Daz Studio?
Post edited by Gen3dx on
  • felisfelis Posts: 6,120
    Try to run Window > Workspace > Update and Merge menus.
    You can either find the dForce menus under Edit > Object > Geometry.
  • The add dForce modifier commands are also in the Simulation Settings pane option menu.
  • Gen3dxGen3dx Posts: 21
    Thanks! It's now showing up again in the Scene context menu after doing that. I'm assuming this has to be done if you have a customised workspace and there's an update to Daz Studio
    That's a place I didn't even know existed. But I've found it now, and it's showing up there. Thanks!
