Anatomical Element textures disappear when I apply Tears.
Finally worked up the [nerve] to ask about this, given the implications that come with me needing both these things applied at once
So, like the title says, when I apply tears to a model's face (like crying tears), the textures on the anatomical element overlay disappears. So I was wondering what I can try to get both of these things to be applied at once? I've tried applying the in different orders and reapplying so far to no avail...
The tears are adding a Geometry Shell for the moisture layer. The preset knows to make that invisible on the rest of the body, but it can't anticipate the Anatomical Elements so you get the untextured shell mesh visible there. If you select the shell and look in the Parameters pane it should have a great long list of surface and group names with an on/off switch - turn off those for the Anatomical Elements.
Thank you so much! That worked perfectly and now I know a little more about how things work!
