Does the FPD Alex for Genesis 9 doorbuster still affect every Genesis 9
I notice that the doorbuster today is FPD Alex for Genesis 9.  He is a very nice product but, once installed, every Genesis 9 character including the ones in the Essentials show about 1% FPD Alex for Genesis 9.  I submittd a ticked last monthg but haven't heard if the problem was repaired and was told that the issue was replicated and submitted for for a future update.  May I get clarity if this was done?
  • ElorElor Posts: 3,463
    There is not update listed on the wiki, so the odds of the issue being fixed are low:
    http://docs.daz3d.com/doku.php/public/read_me/index/102749/start
  • Lee MoonLee Moon Posts: 927
    I noticed that FPD Alex was being applied (at 1%) for all my G9 figures.
    Also, FN James HD for G9's navel is being fully applied to every G9 figure.
    Didn't submit tickets as I didn't think they'd get fixed.
    Lee
  • nemesis10nemesis10 Posts: 3,884
    I submitted a ticket and was told that it it was in the queue to be repaired but it is disappointing that loads of people will get the figure as a door buster in imperfect form.
  • I had the same problem. The reason is that the default value of the Full morph of Alex is set to 1%. You can fix the "FPD Alex for Genesis 9" 1% issue with following steps:
    1. Make a backup of the Alex Full morph file in the Daz directory in case something goes wrong:
    data\DAZ 3D\Genesis 9\Base\Morphs\FreshPixel Designs\FPD Alex for Genesis 9\FPD Alex Full.dsf
    2. Rename the file "FPD Alex Full.dsf" to "FPD Alex Full.zip" because the dsf file is zip-compressed.
    3. Uncompress the file "FPD Alex Full.zip". You will get an uncompressed file "FPD Alex Full.dsf".
    4. Change the value of modifier_library.channel.value from 0.01 to 0
    This is the value in line 31.
    old line:
                    "value" : 0.01,
    new line:
                    "value" : 0,
    5. Save the file.
    6. You can keep the file uncompressed or you compress the file and rename the compressed file to "FPD Alex Full.dsf".
  • Thank you for the fix for this.
