Adding to Cart…
What version of Studio does this work in? I can see it in Studio 4.5.0.114 pro 64bit but It does not seem to be the full version with the extra tabs and stuff. I cannot see it in any 32bit version i am trying to install. I have installed both the 32 and 64 bit version of the plugin, yet I cannot see where to put the serial number in if it even works in this version. I am on a rush to get a flag working in this if someone can tell me what I am missing. I can get the flag working in dynamic in 64bit but I am missing the additional tabs it seems i need to make it work the way I need it to. Any help will be very appreciated.
;-) NM, I update to 4.6 and it all seems to be there. Will see if it does what I need when I get time later this evening.
Is it possible to put dynamic clothing made for V4 onto Genesis 3 female for instance? If so how does the proceedure differ? Am I supposed to parent the clothing prop to G3 in the T-pose for instance? i'm working with the Century Night gown by the way.
I would use a V4 and the other figure
i fit it to her, make it collide with the other one and pose or animate to match then freeze after and delete her
Just line the figure up with the clothing in frame 0, apply your desired pose in frame 30 (or so) and do an animated drape.
Another option is to start your drape animation with the a V4 shape. It's a bit of work (made easier if you have the V4 shape for G2F), but there's a tutorial thread in the forums about making your own clones. Alternatively, this product ( http://www.daz3d.com/wear-them-all-autofitting-clones-and-clothing-smoothers-for-genesis-3-female-s ) has as V4 clone that you can call in if you Show Hidden Parameters.
I've had good results starting with the V4 shape on frame 1 and then using the morphs of what I want the character to be on frame 5 (add a keyframe here), then with a pose added on frame 25.
You should still use the Fit To G3F, then Fit To nothing method, if available.
Well that is definitely a must buy for regular conforming.
