Content Issue- solved
dash2128dash2128 Posts: 736
As I was finishing some work, and about to close down, I noticed that figures and objects turned white.  I didn't think much of it, and shut down.
But when I started up again- a bit later- objects loaded with 'missing files' messages.  And look like they do in the attachment, below.
It looks like all my Content has suddenly done this!
What steps do I take, to fix this issue?
Post edited by dash2128 on
  • NorthOf45NorthOf45 Posts: 5,713
    Check that your DrawStyle isn't set to Solid Bounding Box (Draw Settings tab)
  • dash2128dash2128 Posts: 736
    Ah!  Thanks!   I love a simple solution!!
    I must've reset that, by accident.  Or more likely, when I had that short glitch, at the end of my last shutdown.  I vaguely remember changing the Drawystyle, when I was trying to figure out what was going on.
    Than you again!
  • Could you please change the title of the thread and add (solved)? Thanks.
