How to Make an Object Move When it Can't?
n.aspros123n.aspros123 Posts: 340
edited November 2024 in New Users
I have the Jill's Apartment Environment. It has a chair with a white towel and green cloth(?) I would like to know the step by step proceedure of how to make these objects move when they cannot move?
The chair and it's accessories are not selectable to be moved. I think it needs to be modified with Geometry selector tool but I don't the exact method of how to add a XYZ Axis to make it movable?
See attached screen.
Post edited by n.aspros123 on
  • felisfelis Posts: 6,530
    I have no clue which product you are talking about.
    What gets selected if you click on the chair with the Universal Tool?
    Looking in the part of the scene tab I can see, it looks like there is many individual objects.
    If the chair/towels isn't their own objects, you can convert the overall obect to an figure (if it isn't already), and then with the geometry tool select all the geometry on the chair/towels and create a new bone from selected. Then you can move the bone.
    It's the Chair, White Towel and Green Material on the chair.
    If you can select them in the scene tab, then go to the parameters tab, and check if translate is locked. If so unlock them.
    If not locked, what happens if you move a slider, or type a new value in?
    They Chair, white towel and green material don't show up in the Scene tab. That's why I asked my question.
    They cannot be selected and are not there in the Scene Tab.
  • frank0314frank0314 Posts: 15,111
    What product is that?
  • n.aspros123n.aspros123 Posts: 340
     They cannot be selected with the translate tool and are not there in the Scene Tab.
    Google suggests that this is a game-rip not a proper Daz product. Therefore, it's likely that this has been designed to run effiiciently in the game it came from and probably doesn't have the separated objects you were hoping for.
    You are probably better off taking something like that into Blender I would imagine.
    They're part of the Jill's Apartment Environment app. I'd link it here but moderaters chuck a wobbly.
    I just looked it up, and it seems to be an app and if that is the case it won't be able to move anything without that app I'm thinking. As you suggested, it would be best to take it into Blender or some other modeling app and separated out if you want to move each object.
    Post edited by frank0314 on
    edited May 2025
    The Fridge and Laptop can be selected and moved along the XYZ axis. Why can't they be selected? Look at the list in the Scene tab. There's a couple more items that can be. Surely there's a proceedure to make the Chair, Towel and Green Material be able to be moved.
    1469 x 900 - 148K
    You haven't actually said what get selected in the scene tab, when you select the chair in the viewport.
    n.aspros123 said:
    The Fridge and Laptop can be selected and moved along the XYZ axis. Why can they be selected? Look at the list in the Scene tab. There's a couple more items that can be. Surely there's a proceedure to make the Chair, Towel and Green Material be able to be moved.
    That's a question for whoever you got that product from. It would appear that only some of the items in the scene are separate objects - the ones that are not separate are not designed to be moved or adjusted independantly. If you paid for it then ask for your money back - if it was free then you often get what you pay for.
    Daz Studio is primarily for compositing, arranging and adjusting existing models - it's not really a modelling application (although there are tools and plugins to do some stuff). Therefore, you are usually at the mercy of how things are split up. If you need an apartment environment then there are plenty of others available in the store and the vast majority will have the furniture and other objects as separate props.
    That isn't entirely true - the Geometry Editor, with a bit of export/reimport, can be used to separate items or, as long as they aren't welded, the item can be covnerted to a figure and grouped (if it isn't) then made into a bone with the Joint Editor and Node Weightmap Brush.
    Any tutorials on how this is done please?
    There might be tutorials on geometry editor, but don't know any top-of-mind.
    Essentially you would activate geometry editor, then you can select different ways, box select or polygon selection. I would think for the chair polygon selection is best.
    Select on or more polygons on the different part of the chair (I wouldn't think it is welded). And then rieght click and select connected. (when selecting holding Ctrl let you add, Alt subtracts).
    When you have the whole chair selected, invert selection, and hide selection and probably also delete hidden faces. Then export the rest (as obj), and reimport, and copy materials from the existing. Then you have a chair. I would recommend saving the chair as a new prop.
    Then delete the old environment, and reload. Repeat the selection process with the chair, but this time hide selected polygons (the chair).
    You now have an environment with a hidden chair, and a loose chair.
    Though, if I should do it, I would do it in a modeller instead.
  • LeanaLeana Posts: 13,529
    Here are two tutorials on using geometry editor to edit a mesh, there are most likely others.
