Renderhub zip
2»
  • n.aspros123 said:
    chrisvn said:
    Hello everyone
    I tried to install a character purchased on RenderHub and I managed to get the body and the mesh skin and everything else tells me that there is an error and that I need to look at the log for more detail! Except I'm not the log either
    for the installation of the files I unzipped the inside of the content folder of the Marcus renderhub zip in (A:\Daz 3D Folder\myLibray\Applications\Data\DAZ 3D\My DAZ 3D Library\People\Genesis 8 Female\Characters \Marcius)
    I am attaching some PJs to you
    I'm really bothered plus it's a character that I'm going to use for an animation project for my exam
    Thank you for your help
    Will this YT video help with installing content purchased elsewhere?
    https://youtu.be/xNgcZDlFyJw
    Yes I see this video i doing exactely same but is do not working !!! I really think is my installation the probleme ! as you see on my precedent message with my folder location !!
  • felis said:
    You have 3 folders, but it is unclear what the purpose of those folders are:
    dossierDaz_source: ?
    Installmanager_source: ?
    myLibrary: your content library.
    What lilweep said was that you can have more content libraries, e.g. one for Daz content, and one or more for content from other shops.
    I absolutely want daz to be installed in another disk dedicated to it with the install manager and the library, but does the install manager have to be installed in the daz folder? I'm going to try that this weekend ...
  • lilweeplilweep Posts: 2,753
    edited November 2024
    This is now a completely different topic than the original issue. Im going to assume the original issue is solved.
    Your question now is about relocating/rearraning your Daz installation files on your harddrive? You can probably set the DIM install locations in Daz Install Manager.  But  I have no idea what is in those folders and whether you have set them up correctly and therefore it would be difficult for anyone to advise you on how to maintain all relationships.
    I dont think you can just move everything around and expect it to automatically work.
    Post edited by lilweep on
  • felisfelis Posts: 5,924
    So Daz_source and Installmanager_source is irrelevant from a content perspective.
    But you asked if you could have seperate libraries, and told, that that can you, so you could have a content library (or more) for 3rd party content. Have you dropped that idea?
  • lilweep a dit :
    Il s'agit désormais d'un sujet complètement différent du problème initial. Je vais supposer que le problème initial est résolu.
    Votre question concerne maintenant le déplacement/la réorganisation de vos fichiers d'installation Daz sur votre disque dur ? Vous pouvez probablement définir les emplacements d'installation DIM dans Daz Install Manager. Mais je n'ai aucune idée de ce qu'il y a dans ces dossiers et si vous les avez configurés correctement. Il serait donc difficile pour quiconque de vous conseiller sur la manière de maintenir toutes les relations.
    Je ne pense pas que vous puissiez simplement tout déplacer et espérer que cela fonctionne automatiquement.
    no the problem is not solved since apparently it comes from the way so I did my installation it's not normal that I do like in the explanatory video and that for me it's nothing !
  • felis a dit :
    Ainsi, Daz_source et Installmanager_source ne sont pas pertinents du point de vue du contenu.
    Mais vous avez demandé si vous pouviez avoir des bibliothèques séparées et vous avez répondu que c'était possible, afin que vous puissiez avoir une bibliothèque de contenu (ou plus) pour le contenu tiers. Avez-vous abandonné cette idée ?
    not at all, but I have to understand if my initial installation does not cause problems with my current problem that I cannot see my renderhub characters even though I do exactly as in the explanatory video! I wonder if it doesn't come from my initial installation
    So the only issue is you cant install your Renderhub content but everything else is working fine for you? But even though everything else with Daz Studio is working fine, you for some reason believe there is an issue with your main daz installation?
    I  think if there was an issue with your daz installation you would know because it wouldnt work.
    Logic dictates that if the only issue is with the Renderhub content, then the issue is with how you are installing the renderhub content, not your main daz installation.
    Sorry for dont answer ,
    To tell the truth I don't know that's why I attached my files to you so you can see how I installed it, I nevertheless followed the tutorial to the letter to install the character but nothing worked! I'm learning to use daz as you could see, you told me to first put the body of the female Genesis eight before but there name plus it doesn't work! I can't find a solution to my problem, so I have a question: should the install manager be installed in the root folder of Daz or not?
    Install manager installation is independant of Daz Studio installation. It just need to point to the same content library as is defined in Das Studio.
    It is still not clear to me if you are trying to install 3rd party content to the same content library as Daz products, or you wanted to use a different content library.
    That much i understand. As i mentioned, that problem suggests there may have been a problem with how you installed your renderhub product.
     The solution to your original problem (installing a renderhub zip) may be to do the following.
    1. Create a new library on your harddrive
    1. Find a place on your harddrive.
    2. right click and create a new folder
    3. Call it "Renderhub" or something
    2. Put the renderhub contents into your new folder
    1. Extract the contents or just drag/drop them into the file location
    3. Add the new library to Daz Studio
    1. In Daz Studio, right click on 'Daz Studio Formats'
    2. Add new base directory
    3. Navigate to your new library, and select folder
    4. Now you can see your new library
    If you are still experiencing issues, can you actually say what the issue is? Can you post screenshot of the error message you receive? Can you actually show what you did to produce the error?
    2771 x 1959 - 314K
    3240 x 1595 - 447K
    2781 x 1922 - 407K
    2241 x 1155 - 262K
    yes but I tried both with this character it didn't work! so maybe I did it wrong, I'm going to try step by step what Lilweep tells me, it's my way of going that's wrong!
    Thank you for your step by step i will di that ! so i will comming back for to tell if is ok or not !
  • chrisvnchrisvn Posts: 85
    Hey , normaly this time is ok , I had to put the genesis 8 female body first and when I then clicked on the syph body it was put in its place.... on the other hand she has no hair yet I selected the head correctly! in any case I see how installed now thank you for your patience at everyone
    Hello, I can't apply the hair to him, the eyes yes but nothing else and I found the hair of the other meshes not those of this one wer, for example I put clothes on him to see and it works...
    1878 x 1016 - 214K
    Post edited by chrisvn on
    What is "the hair"?  What are you trying to do? What do you expect to be able to do? What have you tried doing? If there is an error, what does the error say? If you are showing a screenshot of an issue, explain what the screenshot is supposed to be showing.
    My interpretation of your question is that you expect to be able to find a hairstyle in those folders, and you are unable to find such a hairstyle.
    My question would be: does the product come with a hairstyle? I dont think it does.  Therefore, you will need to use another hairstyle from your library.
    1011 x 611 - 57K
    Come on, that's the last thing I would have thought of doing, I was sure there was hair! well thank you I would have looked for a very long time why!!! ok when I ask a question I will elaborate more it was light...
    I also applied the head to the bodysuit! yes indeed ha I'm disappointed i was so happy ! And yes as I saw in the photo with hair I honestly didn't think that he had put it on it's not cool, Thank Lilweep
    1899 x 1053 - 226K
    834 x 955 - 91K
