Failed to write a scene subset
I need some help with this problem. Please. I am battling with the saving and the error issue on DAZ
  • SofaCitizenSofaCitizen Posts: 2,105
    Not sure if it's connected or a red herring but you should probably try uninstalling both 'Emma for Genesis 3 & 8 Female' & 'Wet And Tanned Skins For Genesis 8 Male(s)' and then re-installing them to see if they get assigned new and unique GUIDs. Not sure how multiple products can get assigned duplicate product GUIDs. If I am understanding the log correctly are those installed via Daz Connect (within Daz Studio)? If so, make sure you do not also have versions of the same products installed via any other method.
    If that does not solve the issue then it may be worth getting to the point where you have your subset ready, erasing the entire log, clicking save, and then if the error happens then grab just the contents of the log at that point so only the relavnt entries that led to the error are isolated.
  • crosswindcrosswind Posts: 9,639
    There's a failure of file path creation in OneDrive followed by faile to save modifier asset as well as scene subset. Are you storing / saving the assets in OneDrive ?
  • I think so. Everything sync from my OneDrive. :(
    I personally never use OneDrive... and I used to see folks suggested not install / save Daz content in OneDrive... You may try moving / reconfiguring your Daz Library to other disk ~
