Barbarian belt for a G8F - need help.
tyra_oeildeloup
in The Commons
Hello, I would like to achieve something close to those large belts things on those female barbarians, and I'm not too keen on conversions from other figures because I need it to fit very well, no distorsions etc...What would you suggest to use ? I know of Kadis loincloth but I think this is a bit different...
Maybe one of those?
https://www.daz3d.com/stf-tribal-armor-for-genesis-9-and-genesis-8-female
https://www.daz3d.com/retaliation-outfit-dforce-bottoms-for-genesis-81-females
https://www.daz3d.com/tribal-warrior-queen-outfit-for-genesis-8-females
The problem with Retaliation is that you can't hide the loincloth surface to keep only the belt, although of course I can create the surface I guess...The one by Strangefate is a bit too low on the hips, I don't own the third, I'll check the renders that have been done with it :) Thanks for your help !
Ths autofits to G8F quite well the loin can be hidden
https://www.daz3d.com/dforce-deadlands-wear-for-genesis-8-males
Maybe the belly plackart in this..?
https://www.daz3d.com/stf-bone-breaker-armor-for-genesis-8-males
They both look great, do you think G8M to G8F conversions would be good on those ?
If you don't already have Cross-Figure Resource Kit, I'd recommend picking it up, because that gives you much cleaner conversions than Autofit.
Might be worth trying without the cross figure resource kit & if you're not bowled over by the result, try it with the resource. (I just say this to put off expendature if you've not already spent the money!)
Regards,
Richard
