Charactere G9 all Raw JackStraw Morphing
When i use a G9 Character they all have the RAW Jack Straw Morph, every time i have to delete it to get the original character. What is going wrong? I have attached a file, it is actually an Eden Character a G9. Reqeuest for help. LG Inga Klein
This will be because that morph has been saved with a non-zero default. I don't have that product so no idea if it's distributed like that or you've accidentally changed it yourself.
You should be able to fix this by loading the G9 dev load into a scene, dialling the morph back to zero (unhide hidden parameters if required), going to File > Save As > Support Assets > Save Modified Assets. In the window that pops up it should show a warning that the Jack Straw morph will be amended (which is what you want) and you can click OK. I think that should work - if not then try Memorise > Memorise Figure before the save.
Click the gear icon on the Jack Straw slider and open Parameter Settings and look for the Controller tab - if it is there, what is listed?
