G2m Gens question.
Is there any particular reason that they do not accept the Iray settings? I've tried numerous times, but for whatever reason they will not update with the shading system. I've saved the G2M hip shader preset on it's own, applied it to the Gens after using the SSS and Iray Uber base, and the dials are not in the prop for use with the Iray system. They are completely different than the hip area of the Gens prop, which match the body (hip) area of G2M.
I had this figured out with M4, but the G2M is giving me a headache. :)
Thanks in advance!
You need to have both the object selected and one or mor of it surfaces selected to apply a shader.
Yes, I know this. I have the prop, and the genital surface selected prior to applying the SSS and Iray settings.
Lord. Seems after shutting down Studio and restarting it with a new G2M figure and re-starting the process over, it worked. Good grief, that was a headache. Next time I'll shut down first and see if that fixes the issue.
