DS 101: How to keep smart content category list open
davesodaveso Posts: 7,918
This is a real brain fart, but all of a sudden my category listing is closed when launching DS. I know there is a setting to keep it open, but I'm sure not finding it.
The images show current opening, with all categories collapsed... and the second how I want it when launching DS
  • I'm also interested in this. It would be nice to have it be open when DAZ Studio is launched.
  • crosswindcrosswind Posts: 9,689
    edited October 2024
    The root cause of this "issue" is that one non-default Category (Light Sets) was assign to some of the asset item(s). The default behavior of having two (or more...) root categories in Smart Content is that it auto-collapse the tree of Categorie.
    Deleting that non-default Category (and then reassign the asset to a Category under Default...) will solve it.
    Post edited by crosswind on
  • davesodaveso Posts: 7,918
    thanks...now, how to find what shouldn't be there and how to reassign?
  • https://www.daz3d.com/sy-starry-sky-lights-and-hdris-for-iray
    This set was doing that to me, I went in and recategorized all the parts. Am away from my PC so I can't make a step by step, but if someone else hasn't I'll try to write one up Monday.
    edited October 2024
    You select the Category: Light Sets, you'll see the relevant Product(s) on the right, then click into the product(s) and chase down to the asset item. Right-click > Categorize... to reassign a Default Category to the item,
    Then go back to the Root tree, right-click on Light Sets > Show Category in Content Library. With Light Sets select, right-click > Delete.
    thanks..wow, I know I'm pretty dense, but I have no idea what you;re saying here. I'm in Smart Content. I see the extra Light Sets category. I open it and there is the main thing, SY Starry Sky ...then I click the triangle and several more items open.  I'm not understanding what you're say is the "asset", as there appears maybe thare could be more than one? I do not see anything that says categorize, Only something about a path ... but I have no clue what that would be. I'm assuming when you say root tree you;re in Content Library, and you're deleting that entire category? I might just do that and be gone with that Starry night Product. Would that work?
    I don't have that product so I simulated a case like that... as the attached screenshots.
    501 x 1294 - 81K
    663 x 1391 - 391K
    1495 x 1374 - 543K
    501 x 1294 - 76K
    501 x 1294 - 67K
    thanks agan. You're going way above here. I tried what you posted, and it seemed to work, but now I have just suceeded in deleting the stray light sets category. DS is opening now the way I want it. Think I'll just not install that product again.
    Yep, deleting the category directly is a straight-forward way only there's no category assigned to those items. Uninstalling the product will also do... if you don't need it anymore.
    I've only used it a couple of times. I might try again in the future to install it. I bought a plugin awhle back that assigns things to correct places or something like that. Can't remember the name, but I'll figure that out and give it a go. Thanks again.
