Rigging crash
In both 4.23 beta and general release I get an instant crash to desktop whenever I try to convert a prop to a figure.
The steps I use can be repeated on both versions with the same result. Load a(ny) prop into Daz studio, I've been using a basic cylinder prop, select the prop, click edit>object>convert prop to figure, a dialogue box opens to ask if I want triax or weight mapping, no matter what the selection as soon as I hit accept Daz crashes to desktop immediately, nothing is written to the log file past the loading of the prop.
I have submitted a support ticket but wondered if anyone else is having a similar problem.
windows 10
  • I didn't get a crash just now
  • barbultbarbult Posts: 26,607
    edited October 2024
    It didn't crash for me either, but I have no menu entry "edit>object>convert prop to figure". I have "Edit>Object>Rigigng>Convert Prop to Figure...". I assume that is the menu you meant, since the title here is Rigging Crash. Maybe you have a conflict with a plugin I don't have??
    I am aslo on Windows 10 and 4.23.0.4 Pbulic Build (beta)
    Post edited by barbult on
  • Mart1n71Mart1n71 Posts: 131
    That seemed to be the issue. The Mopat: Motion Path Animation plugin was causing the issue, uninstalling that and everything works as it should. I will update the support ticket also.
